dave@hennessey
Old 06-22-2013, 04:39 PM   #1
pyr0b0y
need....more....hp
pyr0b0y's Avatar
Drives: The Neighbor Hater
Aeromotive fuel system issues
Still having issues with the Aeromotive eliminator system after it being installed over a year. I've been on the phone with Aeromotive for hours, and even paid them an unannounced visit all the way in Kansas. They do not have any idea what is going on, and the marketing director even said he would but a Squash system on my car over an Aeromotive system. They recommended that I just put in a fuel cell to fix the problem....These are the issues I'm seeing:
Running full system with speed controller hooked up to a vacuum switch rather than the tach adapter.
The car will shut it self off at idle (because the controller goes into fault mode)
We checked the voltage to the controller and it is constantly above 14V even at idle. If we turn the key to aux and let the pump run without the car on, it never shuts off, only happens when the car is turned on. We cut out the vacuum switch and hooked it up, and it runs fine, except the pump is running at a 100% duty cycle.
We are thinking the vacuum switch might be bad, but i had replaced the vacuum switch, the pump itself, the controller, replaced ALL of the wiring and checked voltage on multiple places on the car.
I asked Aeromotive about the vacuum switch and if it is big enough to be able to read the vacuum. This is the part number they gave me:
Digikey Corp
480-2060-ND
Operating Pressure 0.04 ~ 0.79 PSI, 1.1 ~ 22" H20
Port Size Male, 1/8" (3.175mm) 27 NPT
Output SPST-NC
Voltage - Supply 120VAC
I think that the operating presure might not be enough for the amount of pressure that I have.
I'm running a 418ci ls3 with twin turbo gt35Rs and am at 10lbs of boost
Any ideas or suggestions would help. I really do not want to pull out my currect system.....
Mast Motorsports Built LS3 Stroker 418, IPS GT35R Twin Turbos, Exedy GTO4XD Twin Disc Clutch, Aeromotive A1000 Eliminator Stealth Fuel Pump, AEM Meth Injection, DSS 1400hp Axels, BC Coilovers, Pfadt & BMR Suspension, Hawk HPS Pads, Drilled/Slotted Rotors, Hurst Shifter, Custom Roll Cage by Blu808, T3 Ports, 22" Custom Concave Mesh Rims
pyr0b0y is offline   Reply With Quote
Old 06-22-2013, 07:33 PM   #2
BullF-16
USAF retired! Thank God!
BullF-16's Avatar
Drives: 2011 1SS, 1LT red,1LT/RS SGM 98Z28
Sorry to hear your problems. I have a brand new eliminator pump and 2 brand new speed controllers in my attic. We had issues after my HKE 427 install and thought it was the Aeromotive stuff. So i ordered the Squash setup. Turns out the issue was not the fuel system but the parameters in the tune dealing with throttle pedal to throttle body/blade settings. So it wasnt the Aeromotive stuff.
Oh well, still glad as hell i have the Squash in my car. Been flawless and is WAY quieter
HKE LSX427(Mast blk lbl 305 6bolt LS7heads, PatG231/246 blower cam, RWHP/TQ: 1281/1133 SNL Performance Custom Twin PT6766 BB turbos 4 to 25psi selectable on the Boost Leash controller, Squash dual 400LPH/ID2000s, ALKY 4 gal meth, Autometer AFR/Bst/oilpres/oiltemp/fuelpress gauges, Pedders Justice road crs pkg: All HD bushes, supercar 12kg coil overs, supercar ZL1 sways, camber plates all setup by JusticePete! :Gforce 9" 35spline S-Trac, 1500hp Outlaw axles, 3.5"alum DS, Monster Triple disc; 4xForgeline 19x10.5 4xBridgestone 305/30R19 RE-11, CTS-v calipers/rotors/Cobalt friction XR1/3 pads
BullF-16 is offline   Reply With Quote
Old 06-22-2013, 07:45 PM   #3
lexlueger
lexlueger's Avatar
Drives: V10 BMW M5, Supercharged 2SS/RS
My recommendation would be to cut your losses. I did. Went with the squash system and haven't looked back. Nobody at Aeromotive could give me a solution to the issues I was having.
MAST 416 STROKER: STAGE 3 TVS 2300
CUSTOM CAM
TPIS 102 TB
IW 8 RIB PULLEY W/ OD COG REARS
NX EXPRESS/NANO KIT
KDI HEAT EXCHANGER/ROTOFAB RESERVOIR
CIRCLE D 2800 TC/FLEX PLATE/ADM TRANS COOLER
DSS DRIVESHAFT/1400 HP AXLES
EATON TRUETRAC -LPE 3.27 GEARS
DYNATECH HEADERS/MAGNAFLOW EXHAUST
SQUASH RETURN STYLE FS ID 850's E85/ FLEXFUEL
BMR/EIBACH SUSPENSION
KILL MODE, ON.
lexlueger is offline   Reply With Quote
Old 06-22-2013, 09:32 PM   #4
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
Drives: Bone Stock LS3
Send a message via AIM to SSE 4 2SS Send a message via Yahoo to SSE 4 2SS
I also have an aero motive paper weight... Went back to the lingenfelter duals in tank and a Weldon external from the cell to the rails via a boost sense regulator... Hella lot'a money to not work...
If the car feels like it is on rails, you are probably driving too slow. -Ross Bentley
Horsepower is how fast you hit the wall.
Torque is how far you take the wall with you.
“If everything seems under control, you're just not going fast enough.” Mario Andretti
If you can turn, you ain't going fast enough...
SSE 4 2SS is offline   Reply With Quote
Old 06-23-2013, 01:41 AM   #5
SRT10KLLR
Drives: 2010 Camaro 2SS/RS
Squash ftw. Call Andy and tell him to hook you up with one of his twin pump units.
You can still use your existing lines regulator etc. Just replace their pumps with his.
2005 Dodge Ram 2500 RCSB Thunder Road Hemi Sport w/STS Turbo
2004 Dodge Ram SRT-10 - Silver - Stock
2003 Chevy 1500 RCSB Stepside 400SS - 408 in now awaiting Turbo
SRT10KLLR is offline   Reply With Quote
Old 06-23-2013, 02:07 AM   #6
blake-b
blake-b's Avatar
Drives: 2009 ZR1
I heart Squash. Well worth going to it. I have had it in my car since Aug 2012 with ZERO issues.
Old 06-23-2013, 09:56 AM   #7
pyr0b0y
need....more....hp
pyr0b0y's Avatar
I've been thinking Squash, but am hesitant just because of all the money ive dumped into troubleshooting the system. For the Squash system, it looks like $800 and I would reuse my Aeromotive Eliminator pump? Does it not have a controller at all? It looks like it only uses a pressure switch?
Old 06-23-2013, 02:27 PM   #8
blake-b
blake-b's Avatar
Drives: 2009 ZR1
The Squash setup is twin pumps 400lph or 450lph (e85 version) in stock fuel bucket. There is no controller. I am running a return style system that uses a regulator and Hobbs switches. Andy is getting ready to debut a returnless system called the Uber Fueler that does everything the current setup does minus the return lines and regulator and is good over 1000hp+.
You would take out the eliminator setup, get rid of the controller, put in the Squash, tune out the FPCM, wire it up and go.
Old 06-23-2013, 02:51 PM   #9
pyr0b0y
need....more....hp
pyr0b0y's Avatar
Any pics?
Wish I would have posted this a week earlier! I was just in KCMO last week! Also stopped by IPS since they've worked with Aeromotive quite a bit.
Old 06-23-2013, 02:52 PM   #10
SRT10KLLR
You would replace the Eliminator pump with the Squash twin in-tank pumps. You should already have the FPCM disabled with your current system. ou can keep the existing AN lines and regulator.
You can sell you pump to make some $$$ back.
I Andy's stuff on a couple of trucks and they have been great. I just received another one from him yesterday that I am putting on the Silverado cause I was running out of fuel with the spray.
Old 06-23-2013, 03:27 PM   #11
blake-b
blake-b's Avatar
Drives: 2009 ZR1
What, exactly, do you want pics of? Upper left corner is the regulator. The Hobbs switch is in the upper right corner. If you can follow the line going over the brake reservoir and see the blue fitting, the Hobbs switch is the silver piece next to it. It comes out the opposite side of my vacuum log. If this isn't what you wanted pics of, let me know.
Old 06-23-2013, 04:27 PM   #12
camarostar2010
Drives: 2011 SS
After speaking with pyro, and seeing a few other posts like this i Will never user aero for fueling my car. If it aint twin walboro pumps, I dont even want to hear it.
camarostar2010 is offline   Reply With Quote
Old 06-25-2013, 07:27 AM   #13
IPS Brandon
IPS Brandon's Avatar
Drives: 2010 Camaro SS black
Send a message via AIM to IPS Brandon
Thanks for stopping by our shop!
Hopefully you can solve the riddle in your fuel system.
IPS Brandon is offline   Reply With Quote
Old 06-25-2013, 08:41 AM   #14
pyr0b0y
need....more....hp
pyr0b0y's Avatar
Thanks for the help and suggestions; you guys really know your stuff !
