TireRack
Old 04-02-2018, 11:13 PM   #15
Juiced1
Drives: 2012 2SS CAMARO 45th
The 2" headers will always give you more trouble. Try loosening the knuckle and you will probably need to put a dimple in the tube.
Juiced1 is offline   Reply With Quote
Old 04-02-2018, 11:22 PM   #16
jbassking
Drives: 2012 SS
Is there only the one bolt to loosen it?
jbassking is offline   Reply With Quote
Old 04-03-2018, 09:15 AM   #17
Badbubba
GrINned & JUICEd
Badbubba's Avatar
Drives: 15STI, 10Expy, 10 2SS/RS M6, 47KB1
1 crimp bolt on steering shaft, then slides apart. Do not let anyone spin the shaft or steering wheel while it is apart.
GPI SS3 Cam & stuff,N.O. Plate(dedicated fuel tank,progressive,fuel hose upgrade,remote opener,heater,console switches),LNC2000,CTAP,ARH 1 7/8" LTs/gutted cats/X pipe/mufflers,Jet Hot coated LTs,GPI HPT Tune,CAI, Scoop,Rx Catch Can,Gates heater hose relocation, Remote clutch & auto brake res,Metco loop,Momentum Tunnel Brace,TSW Nurb 18",555 & 05,Pfadt trailing arms & toe rods,Autometer WB,Fesler Pillar Pod,LED strips (int),Lloyds floor & trunk mats,LED DRL/front turn & license plate,DRL harness,VLEDs tail lights,Plasticoat Bowties. Ord: Oct 5, 2009 Rec: Nov 19, 2009 13.17@112.6 stock
Badbubba is offline   Reply With Quote
Old 04-04-2018, 04:20 PM   #18
Pro-tuned
Angewendet Ingenieur
Pro-tuned's Avatar
Drives: 14 Camaro ZL1
Yes I had to take mine apart too just mark the shaft and realign it.
LQ9, Iron Block, Forged internals, 408CI, Jannetty custom cam, TS short block, Whipple, Hardened Jackshaft, PRC 260, 2X3 Dynatech Full Competition, HF Cats, CAI, NW 103, Chee, ID 1300, COPO Breather, MSD, Fore Dual Pump, ultratorque, E85, dual Meth, True Trac, 3:45, 1500hp axle-shafts, DSS CF, BMR, custom Pearl/Candy paint by Jaidah.
Pro-tuned is offline   Reply With Quote
Old 04-07-2018, 08:47 AM   #19
Powered1le
Powered1le's Avatar
Drives: 2014 2ss 1le
I installed mine on jack stands and had no issues. You have to install from the bottom. Passenger side no issues and left the spark plugs in driver side I had to disconnect the steering wheel knuckle and remove the spark plugs. Other than that I had no issues.
2014 camaro 2ss/rs 1le [muffler & resonator delete, x-pipe , roto fab cai, 305 35 r20 rear tire 285 35 r20 front goodyear f1 supercar,1 7/8" tsp long tube headers with high flow cats, tsp Prc heads, K1 rods, Wisco pistons, 522whp 495tq, dynojet, btr stage3 cam kit, arp head studs and arp bolts.
Powered1le is offline   Reply With Quote
Old 04-11-2018, 09:28 AM   #20
mrWizard
mrWizard's Avatar
Drives: 2010 Camaro 2SS/RS M6
I installed 1 7/8" and didn't have an issue with the steering column.
BUT, I did have an issue with the headers lining up with the factory exhaust. There was a lot of swearing and forcing, but I got it eventually. Almost 4 years and no issues at all.
mrWizard is offline   Reply With Quote
Old 04-11-2018, 10:14 AM   #21
l.o.d_yankee
l.o.d_yankee's Avatar
Drives: 2010/2SS/M6/440ci
I personally couldn't stand the little (tick,tick) exhaust leak coming from the cats and the fact that it necks down to the factory exhaust diameter. I welded some V-bands up and replaced the faux cats with 3' stainless. All leaks gone!
l.o.d_yankee is offline   Reply With Quote
Old 04-11-2018, 10:53 AM   #22
ecreps
Drives: 2014 1LE, 1996 z28
Originally Posted by jbassking View Post
I know this thread is old but I tried installing the left header - TSP long tube - 2" and it won't go past the knuckle in my 2012. Does the knuckle have to be loosened to fit it and then tighten it back up or is this a real issue?
I ran into the same fitment issue, it will go, just try multiple different angles/approaches.
ecreps is offline   Reply With Quote
Old 04-11-2018, 12:37 PM   #23
WheelMan69
WheelMan69's Avatar
Drives: 2015 SS/A6
you can dent the headers it wont do anything to your HP it may even gain HP!!!
Credit: Engine Master
2015 Camaro SS/A6--Roxy MOD'S
*Rear Muffler Delete
*VMAX Throttle Body
*Speed-Engineering Headers / No Cats
*Catted Magnaflow X-Pipe
*BMR Toe Rods
*BMR Xtreme Ant-Roll Kit
*BMR Trailing Arms
*CAI Cold Air Intake
*TUNED BY JAY @ KRAFTSWORKS EXCELL
WheelMan69 is offline   Reply With Quote
Old 04-11-2018, 02:33 PM   #24
SynergyGreenSS
SynergyGreenSS's Avatar
Drives: 2011 2SS
That video always makes me laugh
2011 SS L99
LSA Supercharger, BTR Stage 3 PDS Cam, Yank 3200SS, Weapon X Stage 2 intake, LSA Heads, Flex Fuel, Ported throttle body, Speed Engineering Headers, NOWEEDS, ZL1 fuel pump, DSX AUX Pump, ID-1050X injectors, 3” pipe to NPP mufflers, 3.91 gears
SynergyGreenSS is offline   Reply With Quote
Old 04-11-2018, 08:22 PM   #25
tazman
tazman's Avatar
Drives: 2014 ZL1
Does anyone have information on torque numbers for all of the things related to replacing the headers? Also more information about the steering knuckle if that needs to be moved?
2014 ZL1 Roto-Fab intake, 2" TSP headers, JRE 125 package and tune.
2015 2LT RS overkill tune, 80MM throttle body with JacFab spacer, ported intake manifold and Roto-Fab cold air intake. Vitesse throttle controller.
tazman is offline   Reply With Quote
diy, headers, install
