10-19-2016, 12:59 PM | #1 |
Brewmaster
Drives: 2013 ZL1, 2015 Tundra 1794 Join Date: Jan 2011
vibration from 90mph on up!
wondering if anyone else experienced this problem......when driving over 90 i get this vibration that at first seemed like hitting high seems between sections of the highway. at 100mph + the dash shakes some much the HUD is hard to read...in all of this the steering wheel is motionless so not front end issues. I've been thinking possibly drive shaft or maybe a rear wheel out of balance.....any input before I bring it to the dealer is appreciated.
"Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting "...
holy sh*t...what a ride!" |
10-19-2016, 01:08 PM | #2 |
Had this kind of a thing on my Truck at about 45/50 Mph...Bent wheels. Chances are 9 out of 10 that it's wheel related. It would be VERY VERY hard/impossible (Short of a collision) to damage drive shaft or pieces in the area that would cause a shake like you mentioned on a ZL1.
Just because the steering wheel doesn't shake doesn't mean it's not front end. I'd take it to a dealer and see what they say. |
10-19-2016, 10:53 PM | #3 |
"BEASTM*DE"
Every blue moon I might get up to those speeds, but I have not experienced any vibrations whatsoever...Have you locked the brakes recently and created flat spots in the tires or lost a weight???Seems odd that you wouldn't notice the vibrations at lower speeds...
Vengeance Racing Stage 1 Kit 575rwhp, 569 rwtq...
Rims powder coated gloss black...BFG'S Comp 2 A/S... Dual 10" Kicker Comp S Subs 1200w... |
10-20-2016, 08:03 AM | #4 |
Brewmaster
I don't know how the drive shafts are balanced or if there is a common problem with the bearing between shafts, I could see a wheel balance issue causing this as well. was mainly wondering if there were any known/common (TSBs) issues people are aware of that cause this. thanks for your replies!
10-20-2016, 08:16 AM | #5 |
Put the trans in neutral (or push the clutch in) when the vibration is being felt. If the vib disappears then it's likely in the drivetrain. If the vib remains constant than its probably a tire or wheel issue(bent wheel,bad tire,balance issue) what condition are the tires in?
10-20-2016, 09:47 AM | #6 | |
Drives: 2015 ZL1 Blue Velvet Metallic Join Date: Mar 2015
Roto-Fab CAI, ARH LT, SW 3" catback, JRE tune, Elite-2 CC, VMAX TB, Big Gulp, WW II relo, Lingenfelter S/C reservoir
10-20-2016, 10:54 AM | #7 |
Brewmaster
tires are Mickey Thompson's and have about 6000 miles on them. they look to be in great shape. One of the thoughts that came to mind the first time it happened was that i was feeling the ridges between sections of the road because they were that far apart at 90 mph but at 100-110 it gets pretty significant, so much so that the HUD is difficult to read
10-20-2016, 12:32 PM | #8 | |
Drives: ZL1, 2013, tri-coat-red, manual Join Date: Nov 2013
10-20-2016, 12:35 PM | #9 |
It helps in trying to diagnose where a vibration may be coming from. If the drive shaft is causing the problem when it's spinning and underload putting it in neutral
Can take the load off the shaft. If the vibration stops or changes, then the problem is drive line related |
10-20-2016, 12:45 PM | #10 | |
I'm just trying to understand how to t/s cars, not trying to discredit anyone here.
10-20-2016, 01:34 PM | #11 |
Drives: 2012 ZL 1 #370 Join Date: Dec 2010
I was driving this summer at 250 km/h at german autobahn. Just a little shaking hood.
10-20-2016, 09:52 PM | #12 | |
10-20-2016, 09:57 PM | #13 |
I had a similar issue last year. Had an alignment and tires rebalanced, all went away.
I will also add, that after two track days I will get my track wheels/ tires rebalanced, because they seem to get thrown off pretty well.
2017 ZL1 A10: 8.84 @ 156 PB
2017 ZL1 A10: Previously FBO 756/761 (9.6 @ 143 1/4) SOLD-2013 ZL1 M6:BTR,LTs,IDs,ATI,RotoFab10.84@129 SOLD-2011 SS M6: Blower, Cam, Alky, LTs. |
10-20-2016, 10:10 PM | #14 |
Boosted Moderator
If, and this is a big if, the bolts at the rear end of the drive shaft at the diff are failing, then it may only be noticed at speed, and getting on the clutch, unloading the drivetrain etc, will not effect or improve the situation. The drive shaft rotates relative the tire speed, not the engine RPM's.
If there is no notable vibration in the steering wheel, then I would suspect it is in the rear suspension or in the driveshaft. A flat spotted tire will be more notable at slow speed, and a bent wheel will be notable at all speeds, just at a different frequency. I'm not ruling those out but I would look elsewhere first... You might have a carrier bearing (if the ZL1 has a two piece shaft) failing as well... Get the rear wheels off the ground, put it in neutral, release the parking brake, and see how much play there is is the carrier bearing, and then check the bolts at the differential. Bare in mind, these are one time use bolts... If the drive shaft is removed the bolts should be replaced... I apologize if any of the information is not applicable to the ZL1. I drive an SS and have numerous friends that have had this issue...
If the car feels like it is on rails, you are probably driving too slow. -Ross Bentley
Horsepower is how fast you hit the wall. Torque is how far you take the wall with you. “If everything seems under control, you're just not going fast enough.” Mario Andretti If you can turn, you ain't going fast enough... |
