TireRack
Old 10-03-2012, 04:44 PM   #15
KodyJoe
KodyJoe's Avatar
Drives: 2010 White Camaro SS
I have no idea how much timing the guy added. It runs its ass off for just full exhaust. I had it tuned about a year ago and no problems with it so far (knock on wood).. At the time I had no clue about timing, I'm 19 and just learning by experience, google, and Camaro5 haha!
L99 with CAI, LT Headers, Full Exhaust, and Dyno Tune 374.73 rwhp and 397.18 ft-lbs.
KodyJoe is offline   Reply With Quote
Old 10-04-2012, 09:16 AM   #16
Neal@NitrousOutlet.com
Drives: The Blue Vert
I would be careful. If you have a tune most likely he added some timing. I would verify but you are most like going to have to pull some timing out of the tune.
as far as plug i would go with BR7EF NGKs. The stock number on those are 3346.
If you have questions feel free to contact me. I can guide you.
Neal@NitrousOutlet.com is offline   Reply With Quote
Old 10-04-2012, 10:52 AM   #17
Badbubba
GrINned & JUICEd
Badbubba's Avatar
Drives: 15STI, 10Expy, 10 2SS/RS M6, 47KB1
Kodyjoe talk to the guys at nitrous outlet. They have great customer service and knowledge.
GPI SS3 Cam & stuff,N.O. Plate(dedicated fuel tank,progressive,fuel hose upgrade,remote opener,heater,console switches),LNC2000,CTAP,ARH 1 7/8" LTs/gutted cats/X pipe/mufflers,Jet Hot coated LTs,GPI HPT Tune,CAI, Scoop,Rx Catch Can,Gates heater hose relocation, Remote clutch & auto brake res,Metco loop,Momentum Tunnel Brace,TSW Nurb 18",555 & 05,Pfadt trailing arms & toe rods,Autometer WB,Fesler Pillar Pod,LED strips (int),Lloyds floor & trunk mats,LED DRL/front turn & license plate,DRL harness,VLEDs tail lights,Plasticoat Bowties. Ord: Oct 5, 2009 Rec: Nov 19, 2009 13.17@112.6 stock
Badbubba is offline   Reply With Quote
Old 10-08-2012, 01:12 PM   #18
KodyJoe
KodyJoe's Avatar
So some good news! I found a near by shop that specializes in 5th gens! Their Car FX in Tulsa, OK. I talked to the man earlier today and they mainly do boosted cars and he only has 3 Nitrous cars under his belt. Does anyone know by chance what the stock timing should be? I'm thinking i'll just have him pull enough timing for 150 so I can spray whatever up to a 150 and not worry about it. So pull 6 degrees of timing and use BR7EF NGKs plugs?
Old 10-08-2012, 05:00 PM   #19
SRT10KLLR
Drives: 2010 Camaro 2SS/RS
Every car and combo is different you should dyno and track tune it to be 100%. After you get a handle on the tune on the dyno pull an extra 2 just to be safe and make a 1/4 run and immediately shut the car off at the line. Coast to a safe spot off the track and pull the plugs to make sure you fuel and timing are good. Do that until you are happy with the results.
Pulling 6 for 150 is just a baseline and most of the time I have found that the fuel side is always rich with the recommended jets.
2005 Dodge Ram 2500 RCSB Thunder Road Hemi Sport w/STS Turbo
2004 Dodge Ram SRT-10 - Silver - Stock
2003 Chevy 1500 RCSB Stepside 400SS - 408 in now awaiting Turbo
SRT10KLLR is offline   Reply With Quote
l99, nitrous, questions, tuning
