01-04-2020, 08:38 PM | #1 |
Drives: 2018 ZL1 Convertible M6 Join Date: Nov 2019
Gremlins In The LH Side Mirror Position
About once every 10 times I drive it, the LH side mirror will have tilted up from its memory position (always just straight up, never down or sideways). I've never actually seen when this happens, just notice it when I do a first glance in that mirror. RH mirror never does this. Have played around with the auto tilt in reverse settings by turning it off, just the left, or both - still does the same thing regardless of that setting. I'm the only driver and always use the same key fob. I've set both 1 & 2 memory buttons to the same set up, problem still occurs. Anyone else have this same problem or have thoughts on what could be going on. Or thoughts of additional things to check out? Not a big deal, just an annoyance, but am hesitant to take an intermittent problem that I can not duplicate on demand into the dealer to prevent them from just poking at things. Thanks |
01-12-2020, 07:31 PM | #2 |
Bump - can anyone help? Thanks!
01-22-2020, 06:47 PM | #3 |
Last bump as it looks like I stumped the panel.... :(
12-14-2020, 12:22 AM | #4 |
Drives: Chevy Silverado, Camaro, Traverse Join Date: Oct 2020
I have the same issue but with both sides. 2018 2SS 1LE
12-14-2020, 07:20 AM | #5 |
Thank you Al Oppenheiser!
First guess:
Check the relevant wiring for an intermittent short to ground (rub through, etc.). |
