10-27-2017, 10:47 AM | #15 |
Life's Short, Live Fast!
Drives: 2017 Hyper Blue A10 ZL1 Join Date: Nov 2016
Thanks for the positive thinking!
Life's Short, Live Fast! https://youtu.be/rTUv2p4T7OA 10.94 at 128 mph, 11.13 at 127mph 870 DA, https://youtu.be/e_X_LcpFp50 11.19 at 127mph 1100 DA, https://youtu.be/OXQiCQdQuH4 11.40 at 125mph 1800 DA
https://youtu.be/uWba1qs8M6Q 11.52 at 123mph 3500 DA TZQPHG '17 ZL1 HBM|A10|Nav|PDR|CFW Hood|ZL1 Mats 12/26/2016 Ordered! 2/8/2017 Built!! 3/2/2017 Brought Home!!! |
10-27-2017, 11:28 AM | #16 |
Drives: Crush ZLE M6 | 2000 Corvette FRC Join Date: Jun 2010
That’s hard to look at. Lucky the lady stuck around, and turned out to be a good person. Probably takes a small bit of the “feels” out of the situation versus a hit/run. Hoping the repair is as good as new!
10-27-2017, 11:32 AM | #17 |
Drives: 2017 ZL1 Join Date: Aug 2009
Damn David...that stinks! I'm sure the damage can be easily repaired, like others have said, but will you still feel the same about the car? I certainly don't about mine. Hopefully you can get it fixed and back in your hands quickly.
'17 ZL1 10.99@129 stock. 4225# raceweight. Best 60'- 1.66 on factory tires. 10.48@132 E50, intake and tune. 4270 lbs
https://youtu.be/EyHtdH9XOkY https://youtu.be/Lcu41obbTf8 '13 ZL1 BRM A6. 11.591 @ 119.2 factory stock with a 1.68 60'! Best stock mph 121.8. 11.29 @ 123 RotoFab, drag radials and skinnies. 4360# raceweight. http://youtu.be/yggIA3C_kkA 2014... back to stock http://youtu.be/spQLaTWbThs 2013... stock & RotoFab |
10-27-2017, 11:36 AM | #18 |
#becauseracecar
Drives: 2016 SS Sedan, 2016 Camaro SS Join Date: May 2015
That's too bad.
As someone who is in the industry I just want to let you know you have nothing to worry about when it comes to the paint color. With modern paints it'll be a breeze to match. What they'll likely do is replace the fender and blend the paint into the door and hood. You'll never be able to tell. That paint will be even better quality than the OEM paint. Go to a place that offers a lifetime warranty just in case. Good luck. |
10-27-2017, 11:54 AM | #19 |
Drives: 2017 ZL1 A10 (Summit White) Join Date: Apr 2017
Keep your eye on all repairs. Fender damage should be a quick fix but I'm finishing up my ''repair process'' now and what I am learning is to monitor each phase of the repair.
10-27-2017, 01:58 PM | #20 |
Drives: 2015commemorative vert 2SS Join Date: Oct 2013
How does someone, manage to hit a parked car in a lot? Was she on her dang phone, texting her BFF or?
2018 ZL1 Bright Yellow, A10, PDR, sunroof, carbon hood, and dash- sold
2020 2SS A10 sunroof..shock and steel special-traded 2015 commemorative vert 2ss |
10-27-2017, 02:10 PM | #21 |
#becauseracecar
Look around at other cars next time you're on the road. This is super common. People misjudge the size of their vehicle all the time and figure they can make it only to scrape someone else's car while they're parking. If you see damage to a fender or 1/4 panel, then they got hit. If you see damage to the edge of the bumpers, they're the one that did the hitting.
10-27-2017, 09:02 PM | #22 | ||||||
10-27-2017, 09:08 PM | #23 |
Drives: 2017 Camaro ZL1 Join Date: Nov 2006
Pick a quality body shop, you won't notice it. As Eric SS said, they can match very well these days. Had a gouge fixed on the back of my 2013, had it done at a shop that does daily drivers but also restores cars. I spent 15 minutes trying to see where that gouge was, had my uncle who was a body man all his life try and find it, he couldn't find it. A good body shop will take care of it. Insist on a new GM fender.
10-27-2017, 09:21 PM | #24 |
There will definitely be a new GM fender going on. No doubt about it.
