Old 02-22-2020, 08:21 PM   #15
Uncle Sam
Drives: 2017 Camaro 1LE Hyper Blue
Originally Posted by cdrptrks View Post
Thankfully I was able to sand with the garnet paper by hand after taking off the wheel without removing the rotor from the car. Hopefully that will work for you too if you haven't removed the rotor yet.
I am going to give it a try and see what happens; try the easiest method first.
Any advice on grit? Deglazing rotors usually calls for 1500 to 2000 grit.
Uncle Sam is offline   Reply With Quote
