05-03-2021, 09:45 AM | #1 |
Drives: 17 ss 1le Join Date: May 2021
rumble/vibration when doing a fast, longer turn (like an exit ramp)?
Hi all, '17 SS 1LE. All stock, 7500 miles.
I noticed the other day when going on an exit ramp harder (maybe 3rd/4th gear at 50-60 mph), that the car gave off a slight rumbling feeling. Seemed to be coming from the rear. I only notice it when I push harder on these ramps, not when just cruising on them. Now, when I autocross the car and have say a PTM setting of Sport 1 on, I can feel a similar rumble from the rear when pushing through a turn, which I assume is the PTM doing it's job. But that can't be what I'm feeling on the exit ramp as I am in Tour mode. I'm not pushing hard enough where the SC/TC should be kicking in, and I don't think this would be the eLSD doing it's thing? Dunno, maybe tires (stock SC3)? Car drives great otherwise...just curious if anybody had any input on the rumble I'm feeling under those conditions. Last edited by SS1LETOM; 05-03-2021 at 03:50 PM. |
05-03-2021, 02:39 PM | #2 |
Drives: 23 ZL1 A10 Rapid Blue Join Date: Aug 2020
Checked diff fluid level?
05-03-2021, 03:49 PM | #3 |
05-05-2021, 12:15 PM | #4 |
Drives: 2018 NFG 2SS 1LE! Join Date: Jul 2018
This is exactly what I felt the last time on track, it's always when taking long hard corners with Alot of mechanical grip. Here's my thread I posted last month in the track forum... https://www.camaro6.com/forums/showthread.php?t=591431
The consensus seems to be the tires. It very well could be, just strange that I didn't notice it in previous track days. We'll see if it gets worse as the tires wear. |
05-06-2021, 03:36 PM | #5 | |
Only when I push through a long, fast turn I notice it... My tires are the original tires, so I guess they could be the culprit. Sent you a PM. Last edited by SS1LETOM; 05-06-2021 at 03:54 PM. |
05-07-2021, 12:08 PM | #6 |
Drives: 2017 1ss 1le Join Date: Sep 2015
I had a rumble like this and two new rear axles fixed the issues
05-08-2021, 12:44 PM | #7 | |
Sent you a PM. Last edited by SS1LETOM; 05-08-2021 at 01:18 PM. |
