04-22-2021, 08:42 PM | #1 |
Drives: 2019 Camaro Z-28 Join Date: Jul 2010
Gerting READY for another TRACK DAY
Well guys, I have a 2019 SS with SG3 suspension and 1LE sway bars, ZL1 brakes front and rear, APEX 19 x 10.5 wheels wrapped with 305 30 19 MS 4S tires on all four corners, and VORSHLAG camber plates.
I have run over the last year about 15 track events and I am getting ready for another THIS saturday at Motorsports Ranch in CRESSON Texas. I HAD been running all this time the STOCK brake pads all the way around and I was pleased with the fact that they held up this well. To be sure the FRONT pads were toast and so were the rotors after these track days and about 15K miles of daily driving. The REAR brake pads still had a little wear left in them but I decided to swap them out as well. I was able to have the front rotors turned (barely) and the rear rotors as well. I went with HAWK PERFORMANCE STREET 5.0 PADS on all four corners. I NEVER experienced any brake fad whatsoever with the STOCK pads but I felt like I needed a softer pad to provide a little more initial bite and I wanted a quicker release when coming off the brakes. So far as as STREET driving goes, this is exactly what I got so I expect that same behavoir at the track. I was using the stock brake fluid and i never had any issues with that either but I decided to flush the system out and use for WILWOOD 600 PLUS brake fluid. Supposedly that fluid has a boilover rate at TWICE the DOT4 specs. Occasionally I could smell my brakes after a hard track session so obviously they were getting hot (but still no fade). I got THREE bottles of the brake fluid because I knew some would get flushed out when we were bleeding the brakes. You would only need 2 bottles if you were not flushing out the old fluid. The fluid is priced pretty decently at about 23.00 a bottle. I have some pics attached.
2019 SS 1LE BIG NA A10 Eagles Canyon Raceway 2.7 CCW Below https://youtu.be/c9M5UHDftcA 4-15-23 at SCCA TT U1 Class MEGA Thread on THIS car: https://www.camaro6.com/forums/showthread.php?t=602092 Retired Cars BELOW: 1973 Camaro, 1969 Camaro, 1969 Camaro SS RS 2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10 |
04-23-2021, 12:49 AM | #2 |
Drives: 2018 ZL1, 2001 Z28 1LE Join Date: Dec 2013
What's your best time at Cresson on the 3.1 and/or 1.7? I'm shocked you didn't have brake fade using stock DOT 3 fluid or boil the fluid. Let alone experience any pad to rotor transfer all this time. I'm going to MSR May 1-2! Good luck to you
04-23-2021, 02:16 AM | #3 | |
AMP will be doing some more performance mods to push the engine into the 580-600 RWP area which NA at 3700 pounds should be pretty spirited. Currently I am right at 450 RWHP which is enough for me to do around 135MPH on the back straight at Eagles Canyon. I assume you are doing a DRIVER's EDGE two day event in MAY??? HAVE FUN!!!
04-23-2021, 09:51 AM | #4 |
Drives: 2017 1SS 1LE Join Date: Jun 2016
I'd recommend bringing a backup set of other pads for track use to be on the safe side if you drive hard. While the HPS 5.0 may feel grippier on the street, I'd expect them to fade quite quickly and be worse than stock pads once they get up to track temps if you're pushing the car at its limits.
2017 SS 1LE.
04-23-2021, 10:34 AM | #5 |
doesnt sound like much of a track setup to me i used to have stock pads and michelin ps4s and when i upgraded to me bbk and goodyear supercar 3s i felt alot better on track and faster
michelin ps4s is not a track tire and hps 5.0 pads is more of a street pad then a track pad so be carefull but the new brake fluid should help add some stainless lines also if you want to i have them and they feel great
04-23-2021, 01:42 PM | #6 | |
04-23-2021, 02:15 PM | #7 |
im still on oem brembo pads but i have a 6 piston bbk now but will be switching out to hawk dtc60 next month and yea when i switched the tires to oem goodyear supercar 3s i dropped 3 seconds on my first track day and at next one different track dropped almost 5 seconds seat time and better tires really helps!
i used to daily my car then it turned into weekend fun car now its almost just track only car and you can always get two sets of wheels if you want to!
04-24-2021, 10:50 AM | #8 |
The HPS pads from Hawk won't be. OE pads, especially in ZL1 front sizes, will absolutely outperform HPS pads on the track. You'll want one of the DTC pads for track use, those are Hawk's line of track pads.
2017 SS 1LE.
04-24-2021, 04:36 PM | #9 | |
If I switch out to DTC pads but wanted to also use that pad on the street what compound would work best in your opinion???
04-26-2021, 08:56 AM | #10 | |
The other option would be to get one of the DTC 60/70/80 pads for track use only and swap back to the HPS pads for the street. I hate to regurgitate since it seems like all brake hardware threads turn into this recommendation, but reaching out to KNS Brakes would probably be helpful. They have a good selection of pads and can also make a better recommendation on which specific pads to get based on your ZL1 front calipers to maintain the proper front/rear balance.
2017 SS 1LE.
04-26-2021, 09:26 AM | #11 | |
04-26-2021, 11:15 AM | #12 |
im replacing my supercar 3s next week and switching to hawtk dt60s with my zzp bbk i have so ill let you guys know lol i dont drive car on streets very much just pretty much just to track and back so wish me luck!
