08-18-2019, 10:05 AM | #1 |
Drives: Anything I want Join Date: Oct 2008
New in the box - 2016-2019 Camaro SS 1LE LT4 SC Install parts kit
I have some overstock of these "LT4 SC 1LE Install Kits" we are letting go for a pretty hefty discount from our normal web price. This is the most complete install kit with extras on the market today. The price is $2695 plus shipping
() ADM PULLEY 2.70,2.50,2.35 (Please specify the supercharger Zl1/Corvette you have in notes during checkout as well as pulley size your interested in) () ADM ADAPTER PLATES () LT4 TENSIONER BRACKET () LT4 TENSIONER FOR SC () PULLEY SMOOTH SMALL () PULLEY RIBBED SMALL () PULLEY RIBBED LARGE () ZL1 DAMPNER () HOSE SC TO PUMP HOSE () HOSE PUMP TO LEFT H/E () HOSE LEFT H/E TO CENTER H/E () HOSE CENTER H/E TO SC INLET () HOSE FROM RADIATOR TO RGHT HE () RADIATOR ADAPTER HOSE () BOLT 10MM X 100MM X 2 () BOLT 8mm x 55mm x 2 () BOLT 8MM X 50 X 3 () WASHER 8MM X 5 () WASHER 10MM X 2 () 6MM LONG BOLT X 6 () 6MM C NUT X 6 () 6MM WASHER NUT X 6 () 8MM STUD AND NUT X 1 () SELF DRILLER BOLT #10 X 4 () DUCT FOR INTAKE () DAMPER BOLT () LT4 T MAP SENSOR () INTERCOOLER PUMP () LT4 VALLEY COVER WITH EXTENSION PIPE () ZL1 HEAT EXCHANGER () BRAKE BOOSTER PIPE LONG () BRAKE BOOSTER PIPE SHORT () HARNESS FOR PUMP () HORN BRACKET () PUMP BRACKETS () T MAP EXTENSIONS ADAPTER TO MAF IAT BREAKOUT () PURGE VALVE EXT HARNESS () HOSE KIT WITH ADM RESERVOIR AND BRACKET - OPTIONAL () HEAT SHRINK () EVAP HOSE () CLEAN AIR PIPE () 4 HOSE CLAMPS I also have a set of 8 - New LT4 Injectors for $428.40 plus shipping(while supplies last) as well as LT4 HPP - $638.10 plus shipping (while supplies last) I even have multiple New/Used takeoff Zl1/Ctsv/Corvette Superchargers with ADM 2 Piece pulleys starting off at $1800.00 (1 year warranty against manufacture defects on the new take off models) New in box - Lt4 Zl1 Intercooler Pumps - $225.90 To receive these prices on the above you must purchase from - lsaconversion.com website and use discount code - Camaro6 at check out. Last edited by ADM PERFORMANCE; 08-18-2019 at 10:16 AM. |
08-18-2019, 10:10 AM | #2 |
Your post doesn’t say how much the kit is...? I have a buddy who just picked up a ‘17 SS who was considering going this route so I can pass this along to him.
08-18-2019, 11:45 PM | #3 |
Drives: 2018 Camaro SS 1LE Join Date: Jul 2018
PM sent for questions. Thanks!
08-22-2019, 07:29 PM | #4 |
This is te install kit that is discounted
08-23-2019, 07:00 AM | #5 |
As of this morning - 1 left at this price
As of this morning we only have 1 of these discounted kits left,
and 1 - set of LT4 Injectors left and 1- LT4 High pressure fuel pump and 4- intercooler pumps Once these are gone the price will increase. |
08-25-2019, 12:16 PM | #6 |
Last one sold
The sale is now over and the prices are back to normal.
08-25-2019, 09:43 PM | #7 |
Andy - thanks!
11-01-2019, 11:47 PM | #8 |
Drives: 2017 ss1 camaro Join Date: Apr 2015
let me know when you have more
