Old 08-18-2019, 07:25 AM   #1
Tim M
Drives: 2018 Camaro SS 1LE
PDR Speed Accuracy?
I've got a 2018 Camaro SS 1LE with PDR on OEM tires.
Curious if anyone can confirm the accuracy of the speed on the PDR recording - ie compared to GPS?
I believe the speed is pulled from the VSS as I've gotten wheel spin/skip on bumps and the speed jumps up accordingly - see recent ring lap with multiple 'hops'.
I know my C4 Corvette speedo was quite accurate even at high speeds, but typically cars (especially European models) have a ~3-4 mph conservative error. My experience on older motorcycles was simply a percentage error - ie 139 MPH indicated equaled a real MPH of 125.
Bottomline: how accurate is the PDR?
Thanks.
Tim M is offline   Reply With Quote
Old 08-18-2019, 03:59 PM   #2
Camarentino
Camarentino's Avatar
Drives: 2018 Camaro 1SS 1LE
It's a little off both mph and time. At the track my pdr showed 13.09 @ 115 but track time slip says 12.91@113. It's a good tool to have but it's not 100% accurate
2018 Camaro 1SS 1LE w/PDR Summit White
KN intake-MBRP cb- 2nd cat deletes- ACS sides- iroc Z spoiler- Eibach Pro- Katech 95TB- MSD Manifold-GM strut bar- Custom tune by Arun Ahuja @ CCPERF.ca
Camarentino is offline   Reply With Quote
Old 08-19-2019, 05:33 AM   #3
beedo
Drives: 18 2SS 1LE NFG
Mine is dead on within .5 MPH, I have a uniden R3 radar detector that displays GPS speed and the are usually the same give or take maybe .5 mph
beedo is offline   Reply With Quote
Old 08-19-2019, 05:53 AM   #4
wnta1ss
Drives: 2017 Camaro 1SS
There was a PDR video of an SS/1LE running on a speed track posted, and the speed reported on the PDR was 174. The timed speed was 172, so it looks like the speedometer is very slightly optimistic on that 1LE.
Old 08-19-2019, 07:39 AM   #5
Gary H
Drives: Camaro ZL1
If the difference at 172 is 2mph, that works out at just over 1%, which I would say is pretty much as spot on as you can get!
Made in the USA. Refined in Great Britain - insta: zl1uk
Velossa intake, Rotofab, Mamo TB, Custom ported NX Lid & Jokerz Full tilt ported LT4 charger, 3 port CoolingMist Meth injection - ATI 15% lower pulley, E2X CC, TSP ceramic coated longtubes, de-cat and Borla 60608 to NPP box, JRE tune, BMR rear control & trailing arms, lock-out kit, lowering springs and front strut brace, Custom carbon trim interior, Xpel ultimate front PPF and Prestige window tint with Chameleon Windscreen tint...ever evolving...
Gary H is offline   Reply With Quote
Old 08-19-2019, 07:45 PM   #6
Tim M
Appreciate the replies.
I'm curious at the high speed accuracy.
For quarter mile: believe most tracks use an average of a short distance at the end of the quarter mile rather than a snapshot speed like the PDR gives.
I would imagine tire wear and pressure will play a part too.
Likely I will just buy a GPS to verify, if I'm curious.
Old 08-19-2019, 07:59 PM   #7
Scargoes
Scargoes's Avatar
Drives: 2018 Hyper Blue 2SS 1LE
Federal motor vehicles standards are vague but give about a 5% error to manufacturers above or 2% below, EU does not allow any below % thats why they all read high. But Car and Driver had a story back in 2002 that revealed that in their testing of all domestic makes, GM had the most accurate https://www.caranddriver.com/feature...meter-scandal/
That being said, the gps speed displayed on my phone is within 1mph of my headsup display, and thus the PDR display, every time I've checked it.
2018 Hyper Blue Metallic 2SS 1LE with Nav, PDR, and track alignment
1:34.20 Willow Springs Big Track
Scargoes is offline   Reply With Quote
Old 08-20-2019, 06:37 AM   #8
wnta1ss
That PDR video that I was referencing was not far off as far as percentage goes.
1/4 mile dragstrips these days get speed from the average of the last 66' of the run. The 2.7 mile run that video was from probably averages the last 132' of the run.
Old 08-23-2019, 02:59 PM   #9
Timbo-1LE
Timbo-1LE's Avatar
Drives: 2017 SS 1LE
PDR
PDR said 174, this was official timing just under 173, pretty close...
Timbo-1LE is offline   Reply With Quote
