08-17-2019, 05:15 PM | #1 |
Drives: i want a camaro Join Date: Aug 2019
rear breaks for LT camaro
how do I get the rear SS-style breaks for the LT Camaro equipped with the heavy-duty break and cooling package or Brembo style(or high performance) break pads
thank you |
08-17-2019, 10:48 PM | #2 |
Drives: 2019 2LT 2.0T M6 Riverside Blue Join Date: Jan 2018
unfortunately you can't, the parking brake is integrated into the rear calipers and cannot be retro-fitted. The SS rear brakes have a different parking brake mechanism that cannot be transplanted onto an LT car. You could bolt them in and hook up the brake lines and they would work, but you would have no parking brake. Keep in mind, the rear brakes don't do that much, so replacing the rear calipers would not be a performance upgrade. Some really don't like the look of the OEM calipers in back, but you'll probably get used to it.
08-17-2019, 11:42 PM | #3 |
there is always a catch, in that case, do you recommend some good rear break pads that are similar performance to the Brembo front pads
thanks |
08-18-2019, 12:08 AM | #4 |
Drives: 2SS 1LE Join Date: Oct 2011
You don't want to break your camaro.
2018 2SS 1LE 2023 Colorado ZR2 2022 Stinger GT-line AWD |
08-18-2019, 12:41 AM | #5 |
I don't want to "break" as in damage the car I meant what kind brakes do you recommend that are Brembo like performance for the rear
omg |
08-18-2019, 01:16 PM | #6 |
Drives: 2024 Riverside Blue 2SS 1LE Join Date: Mar 2016
I really don't think it's a good idea to only modify the rear brakes. If you want to upgrade I would do the fronts first since they do 70% of the stopping. Maybe get some better rotors and pads to start. Some good information in the Brake section in the forum.
08-18-2019, 01:45 PM | #7 |
Drives: 2018 1SS 1LE & 1973 Datsun 240Z Join Date: Sep 2015
If you're talking about improving brake torque, upgrading the front brakes only will actually result in longer stopping distances. The torque from the rear brakes is what generates load transfer to the front wheels. Without that, your upgraded front brakes are going to more easily overcome the grip of the front tires making it harder to stop. Saying that the rear brakes don't do much is a common misunderstanding of how brake systems work. The balance between front and rear is critical for optimum braking, and that balance needs to be maintained.
Nigel |
08-18-2019, 04:06 PM | #8 | |
Try this with a bike, where you can use the brakes independently, you'll see what I mean. The front most certainly does ~80% of the braking. If you are overpowering the grip of your front tires, it's most likely because your rubber is not sufficient for the braking power. You'll most likely notice insufficient rear brakes by the rear end coming loose easier and sideways skids. Acceleration causes the rear end to squat, transferring weight to the rear. Deceleration causes the opposite of this, transferring weight to the front.
08-18-2019, 07:03 PM | #9 | |
08-18-2019, 07:10 PM | #10 |
Dumb Ass Deluxe
Drives: A Tricked Out Mountain Bike Join Date: Jun 2019
^^Cocaine is a helluva drug....
08-18-2019, 08:59 PM | #11 |
That all makes certain assumptions that you can't prove. A proportional increase in rear braking is needed, except that assumes you had the proportions and rear power perfect before you got the new front brakes, while things like wheel size, tire size and composition, airflow to the brakes, are variables that could throw it either way. In many cars, the rear calipers are kept the same between trim levels while the front brakes are increased. My BMW with optioned M-sport brakes had upgraded rear and front calipers/rotors, however, the higher trim and heavier 435 had the same front calipers and smaller rear brakes and calipers. The 1LE has bigger and more powerful front brakes than the SS, but the same rear rotor and calipers. The same brakes I had on the BMW could be optioned on the 435, but the smaller rear caliper/rotor was obviously determined to be adequate. Given similar situations and other variations of the same (manufacturers that keep the rear calipers the same and change the front brakes between trim levels) I would bet there is some decent wiggle room in there. Unless you are doing far more testing to determine the actual %, effects of heat and so on, it's probably best to upgrade the front, see what happens, and upgrade the rear if necessary. That is probably going to work well and provide better braking more than 50% of the time, but there will inevitably be situations where the rears should be upgraded too.
2018 2SS 1LE 2023 Colorado ZR2 2022 Stinger GT-line AWD Last edited by JamesNoBrakes; 08-18-2019 at 11:58 PM. |
08-18-2019, 11:57 PM | #12 | |
Nigel |
08-19-2019, 12:30 AM | #13 | |
2018 2SS 1LE 2023 Colorado ZR2 2022 Stinger GT-line AWD Last edited by JamesNoBrakes; 08-19-2019 at 09:09 AM. |
08-28-2019, 09:14 PM | #14 | |||
Using the Mustang as an example, the same rear caliper is used on the base Ecoboost, all the way up to the GT Performance Pack 2. However, despite going from a 2 piston floating caliper on the front of the base model, to the optional Brembo 6 piston front caliper on the GT, the Brembo front caliper only has a 5% greater piston area. Yes, the front rotor is significantly larger, but a slightly larger rear rotor is fitted as well. More importantly though, the GT is a heavier car, and it has stickier tires. Consequently, biasing more brake torque to the front makes sense. Sure, there's some wiggle room, but deviate too far and things quickly start to go downhill... Here's a link to an article with test results that show how increasing the diameter of the front rotor on an Audi S4 by only 7% (about a 10% increase in front brake torque), while using the same caliper, resulted in longer stopping distances... https://www.zeckhausen.com/catalog/i...Path=6446_6565 That article also demonstrates the challenges in making improvements to a braking system. Here's a quote from an excellent article by Stoptech on brake bias (link to the full article is below) Quote:
Which is not to say that OEM'S always get it right either. Pre-2001 Dodge Vipers were notoriously overly front biased. They came from the factory with a 36mm piston rear caliper. After many complaints of front wheels locking up too easily, a rear piston upgrade mod to 40mm was developed for those earlier Vipers which resulted in a braking force increase from 0.8G's to 1G with no other changes. Here's a very detailed forum post from Stoptech in a Viper forum on brake bias, in response to questions about rear brake upgrade options on Vipers. https://www.viperclub.org/vca/thread.../#post-2068464 So, dismissing rear brakes as only having a minor roll, and/or focusing only on front brake upgrades, particularly if they are going to increase brake torque, is very likely to make things worse. Even something as simple as installing front pads with a higher coefficient of friction, which is a common first step that a lot of drivers make, can negatively impact braking distance. More often than not, the homegrown front brake upgrade, whatever it may be, doesn't taken any of this into account. But the driver then marvels at how they can lock up the front brakes easier now and concludes that he's 'improved' the braking. In reality, the braking distances likely just got longer, contradicting the expectation. With respect to the Camaro, the engineers appear to have done an excellent job with optimizing brake bias. Consequently, I'd be very cautious about making any changes to upset that, particularly given that the system will already be designed with a slight additional front bias for stability. So, for example, if you want to try a different pad compound, run the same compound on the front AND rear of the car. |
