08-12-2019, 06:44 PM | #1 |
Drives: 2019 1SS Crush, 2017 Corolla White Join Date: Dec 2016
Trunk won’t open hero third brake rapid fire installed
So when I got my car my trunk would open sometimes other times no matter which button I pressed it would just click and not open. The issue would resolve it self after a day or so didn’t think too much about it. Installed the hero third brake light rapid fire module about a month ago for safety concerns on the highways here in Texas. Fast forward to last week the trunk won’t open at all. Dropped it off at the dealer today, their saying it’s not throwing any codes so it shouldn’t be any electrical, however the third brake light flashed could have fried something and it’s a $800 fix. Don’t know if I should take it to another dealer? Because it sounds like a latch problem especially from what I have seen on the forums here. What’s y’all take?
Through Christ
08-12-2019, 06:45 PM | #2 |
swap out light take to another dealer
08-12-2019, 07:48 PM | #3 |
Drives: 2017 ZL1 Convertible A10 Join Date: Aug 2017
'17 White ZL1 A10 Convertible - TM ported TB - RotoFab CAI - 2.3" griptech upper pulley - Kooks 1 7/8" Headers with High Flow Cats - Borla S-type Catback - Audio Overhaul - NavTV M650-GM - 20" BlackDiForza- Michelin Pilot Sport4S - Tuned at BRC Raceworks (606rwhp/675trq)
'14 CTS-V Coupe - ZL1 lid - Ported TB - Ported Snout - AirRad CAI - 8.66" lower - 2.55" upper- Greenbelt - SW Headers - SW Catback - Varimax Intercooler Pump - Track Attack Intercooler-Tuned at BRC Raceworks (551rwhp/516trq) '17 Maserati Levante- STOCK |
08-12-2019, 08:05 PM | #4 | |
Drives: '17 Red hot 2ss, 16 Focus RS Join Date: Aug 2015
"Spitfire" 427ci
2017 Red Hot 2SS// 6 Piston Brembos//Adrenaline Red Interior, Knee Pads//M6//MRC Afe Air Filter//BMR MM010 Motor Mounts, Safety Loop//Custom OTR Intake//Flex Fuel Kit//Gforce 3.5" Aluminum Driveshaft//GM 95mm TB//Katech Oil Pump, Piston Squirters//Kooks 1-7/8 LT//LT4 Fueling//Mighty Mouse Wild//Monster Clutch LT1-S Triple Disc//MSD 2-Step//Pray Performance Custom Spec Cam, Ported Holley Hi-Ram//Sikky 12" Shifter w OEM Knob Mod//Tick Level 1 Tr6060//Labor by Me//Tune By Pray Performance |
08-13-2019, 10:30 AM | #5 |
Drives: 2016 Camaro 1LT Join Date: Jan 2016
the height adjustment bumpers on the trunk and the interior plastic cover that wraps around the trunk hook latch need to be carefully adjusted. You will not pop the lock if it's not making contact for instance. It needs a certain amount of contact pressure on that plastic cover to work.
