Old 04-25-2018, 11:41 AM   #1
ScottMZ3
ScottMZ3's Avatar
Drives: 2018 ZL1 A10, 2019 BMW X5
Creaking interior door pull
Anyone else’s 6th Gen interior door handle make this creaking sound (both sides)? It’s right at the grab point so I hear it every single time I open/close the door. It appears there is plastic on plastic between the suede pad and the LED trim piece. Wondering if I could just remove the pad and put some felt tape behind it. Anyone know how to remove the pad?
See video for the issue:
https://youtu.be/_VAEw0jQnJI
2018 Nightfall Gray Metallic Camaro ZL1 - A10
Purchased 9/23/2017
ScottMZ3 is offline   Reply With Quote
Old 04-25-2018, 02:50 PM   #2
pjz1082
pjz1082's Avatar
Drives: 2016 Camaro 1LT
I don't have that noise but the knee pads basically pop off. Just use a plastic trim tool and work your way around. There are multiple YouTube videos that show how...Like this one...
pjz1082 is offline   Reply With Quote
Old 04-25-2018, 04:25 PM   #3
ScottMZ3
ScottMZ3's Avatar
Thanks!
I had success. Removed both pads and installed felt tape in quite a few areas...the creaking is 98% gone. Much better!!
EDIT: Not sure why, but the YouTube video's aren’t showing up in the posts on any of my devices. Any idea why? Just get a white box where it should be.
Purchased 9/23/2017
Old 04-25-2018, 04:55 PM   #4
pjz1082
pjz1082's Avatar
Doing the same to me. Probably some YouTube rights thing I would guess. Glad you got it figured out though.
Old 07-18-2018, 10:40 PM   #5
Mando895
Mando895's Avatar
Drives: Hyper Blue Metallic 2017 Camaro 2SS
I tried using the felt method, and it seems to have helped a lot (although the creaks aren't entirely gone...). I would also recommend checking to see if the philips screws are fully tightened. I was able to slightly tighten a few by hand, and it seemed to make a big difference.
Attatched are some pictures of my doors with the felt installed, a picture of the backside of the leather pad (to see where the connectors are), and a picture of the felt I used (purchased at Michaels for $1.30).
P.S. I HIGHLY recommend using scissors to cut the felt. It is nearly impossible to cut with a blade (at least from my experience).
2017 Camaro 2SS Hyper Blue Metallic
8-Speed Auto, Magnetic Ride Control, Borla S-Type Exhaust (NPP), HRE FF10s (Tarmac), Michelin PS4S Tires,
Rotofab CAI, SEMA Grille, Mishimoto Oil Catch Can, StopTech Slotted Rotors, PowerStop Z26 Pads
Also Own:
- 2004 Lexus RX330
Mando895 is offline   Reply With Quote
Old 03-26-2019, 05:31 PM   #6
DC5
Drives: 2019 Chevrolet Camaro SS 1LE
Thank you to those who have contributed to this thread. Today I installed felt on my driver side door panel, and it did reduce some of the noise emanating from the door pull. However, there is still noise occurring somewhere from the window switch when opening/closing the door. I suspect it is originating deep from within the plastic "cradle" that holds the window switch panel because if you keep your fingers off the small portion of this panel that composes the door pull, there is zero noise. For now, however, I'm going to leave it alone.
DC5 is offline   Reply With Quote
Old 03-26-2019, 08:00 PM   #7
Azerlazer26
Azerlazer26's Avatar
Drives: 2018 Camaro 2SS
I’ve had this problem for a while but I can live with it. Only annoying issues I’m having is that my speakers are making my door vibrate like there’s no tomorrow and a VERY annoying rattling noise thats appearing when I floor the gas pedal :/
Azerlazer26 is offline   Reply With Quote
Old 03-27-2019, 02:05 PM   #8
51FIFFT
Drives: 2017 2SS M6 FIFTY @51fifft
Mine is the steering wheel bottom right by the buttons.. i had to wedge paper in it on my last long road trip. drove me crazy.
51FIFFT is offline   Reply With Quote
