Old 04-23-2018, 07:56 PM   #15
KSA464
Drives: 2018 2SS
check out ebay too. I bought a dozen PF64's for $62- shipped free. I also bought a dozen Purulators for the Silverado a couple years ago for like $50 as I recall. I have enough filters at a bargain to last the life of any vehicle I own as I conduct my own oil changes.
KSA464 is offline   Reply With Quote
Old 04-23-2018, 07:59 PM   #16
carguy55
carguy55's Avatar
Drives: 2018 1SS 1LE
I bought the PF64 at the local Wal-Mart along with the Dexos2 oil. I wouldn't use UPF64R. It's listed on ACDelco's website as a filter for 4 cylinder engines only.
Old 04-23-2018, 08:08 PM   #17
Marko
Marko's Avatar
Drives: Camaro
Well. I was able to also buy the PF64 today too. LOL. I guess I’ll just use that one.
Marko is offline   Reply With Quote
Old 04-23-2018, 08:37 PM   #18
soloknight6
SoCal HT5! SD
soloknight6's Avatar
Drives: 2016 red hot 2ss M6
"GM CUSTOMER CARE & AFTERSALES
URGENT - DISTRIBUTE IMMEDIATELY
DATE 02/25/2016
SUBJECT Oil Filter Usage
MODELS 2016 Buick Encore, Chevrolet, Malibu, Cruze, Spark, & Volt Equipped with Engine RPOs LE2, LV7, LFV and L3A
TO All Chevrolet, Buick, & GMC Dealers
ATTN Parts Managers, Service Managers, Service Technicians and Fleet Service and Part Managers
The new small gas engines launched in the 2016 vehicles use oil filter P/N 12667194.
This P/N has been superseded to P/N12670058, then superseded to P/N12674698 (AC Delco UPF64R).
If this part number is unavailable you can use oil filter P/N 12640445 (AC Delco PF64) until stock becomes available for the P/N12667194 - P/N12670058 – P/N12674698 oil filter (AC Delco UPF64R).
Thank you for your cooperation.
END OF MESSAGE
GM CUSTOMER CARE & AFTERSALES"
Meh, I'd stick to the pf64. The P464r has a bypass rating of 35PSI to accommodate the high pressure in the small GDI engines, versus the 22PSI Pf64 engineered with the larger GDI (LT1) engines in mind.
Attached to this post is a recent service bulletin which concerns the LT1 engines and PF64 filters. Hope it helps!
*I am in no way an expert on oil filters. Just posting my amateur findings. Come to your own conclusions.*
File Type: pdf 2012 - 2017 Corvette_ Service Bulletin_ #17-NA-157.pdf (161.3 KB, 149 views)
soloknight6 is offline   Reply With Quote
Old 04-23-2018, 08:51 PM   #19
Marko
Marko's Avatar
Drives: Camaro
Just like in this thread. The Wix isn’t the exact as the PF64
https://www.camaro6.com/forums/showthread.php?t=524437
Old 04-23-2018, 08:58 PM   #20
soloknight6
SoCal HT5! SD
Exactly. But in regards to the two filters brought up in this thread,
The PF64R, (35PSI)
The PF64, (22PSI)
The LT1 engine calls for a filter with a 22PSI bypass valve. GM has clearly stated, that any filter bypass valve LESS THAN 22PSI is not adequate for the LT1 engines. But I couldn't find any information from GM about using a filter with a bypass valve GREATER THAN 22PSI in the LT1, but I'd guess it would be a no no...
Please correct me if I'm wrong guys.
Old 04-23-2018, 09:04 PM   #21
RacerX78
Drives: 2018 Camaro SS 1LE
Had a long conversation with a parts manager about the 64R and after some research, we found where the 64R fits the LT1. I'm currently using it because it is constructed better than the standard 64. I'll be getting a UOA to keep an eye on wear.
Camaro SS 1LE ACDelco Oil Filter Specs Full.pdf
RacerX78 is offline   Reply With Quote
Old 04-23-2018, 09:15 PM   #22
soloknight6
SoCal HT5! SD
Attachment 931784
Nice find! Looks like the 64R is suitable for the LT1!
Old 04-23-2018, 10:08 PM   #23
Marko
Marko's Avatar
Drives: Camaro
One more thing: I’m surprised how small the oil filter is on the LT1
Old 04-24-2018, 05:32 AM   #24
mdhopt36
Drives: '17- 1ag37 V6 traded, for 1SS 2018!
Had to go to dealer to get a PF64.
I went to NAPA, and the guy told me WIX made their filters.
Asked him what the relief was set at, and he looked it up
As 11-17psi.
Plumb Auto didn't have the PS64 either. He confirmed the WIX as being 11-17psi as well.
Dealer was right at $10, but at least I got a suitable filter.
mdhopt36 is offline   Reply With Quote
Old 04-24-2018, 06:35 AM   #25
vtirocz
vtirocz's Avatar
Drives: 2017 Camaro 1SS M6
As 11-17psi.
Walmart usually has them for less than $5.
2017 Camaro 1SS, M6, Hurst shifter, Hyper Blue, NPP, Gray Split Spoke Wheels
Best 1/4 Mile: 12.24 @ 115.9 mph
Old 04-24-2018, 02:42 PM   #26
Marko
Marko's Avatar
Drives: Camaro
I just got my oil changed. Everything went great. The engine sounds quieter. And maybe it runs better. I used Mobil 1 and PF64
Old 04-24-2018, 08:39 PM   #27
Biscuit.fr
Drives: Red hot ZL1 A10 2017
Walmart 6$
Biscuit.fr is offline   Reply With Quote
Old 04-24-2018, 08:42 PM   #28
enzia35
Drives: '16 Garnet Red 1SS
You've way overthought it btw.
'16 Camaro 1SS
'18 Miata GT
