Old 02-24-2017, 12:01 PM   #43
2016SS
2016SS's Avatar
Drives: 2016 Summit White 2SS
I had mine taken off i prefer the look with out them never had a issue mines just a toy so I only drive it in the summer.
To answer your question your fine with out them or with them.
2003 Cadillac CTS Sold
2006 Nissan 350Z Sold
2008 Cobalt SS/TC Sold
2016 Camaro 2SS Summit built 3/28/16 delivered
2018 Camaro ZL1 cancelled by GM 😡
2019 Corvette 2lt Z51
2016SS is offline   Reply With Quote
Old 02-24-2017, 12:54 PM   #44
JAM32
JAM32's Avatar
Drives: 2017 1ss 1le Red Hot
so on a different thread I saw the manual advises taking them off for track events. but doesn't that contradict the idea they are there for high speed aerodynamics? I've done two track events, small time attack things, and left them on. Has anyone else taken them off for track, and if so then what's the point of having them at all?
JAM32 is offline   Reply With Quote
Old 02-24-2017, 02:27 PM   #45
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
Yes.
There is the front tire deflector. And then the control arm brake deflector.
The tire deflector will likely block airflow from hitting the taller control arm deflector, so they advise it gets removed.
However, they do provide aerodynamic benefits in terms of drag and turbulence for the benefit of fuel economy. Which is why they are used for street use.
Old 02-24-2017, 02:37 PM   #46
E-Ray
E-Ray's Avatar
Drives: 2016 Camaro 2SS, Nightfall Grey
"And rather than a traditional front air dam to reduce aerodynamic lift, the team developed a flush belly pan that stretches from the front grille to the center of the vehicle. Paired with small “spats” forward of the front tires, the smooth underbody helps reduce total lift by 30 percent – while also reducing aerodynamic drag."
http://media.chevrolet.com/media/us/...ro-teaser.html
2016 Camaro 2SS, Nightfall Grey,
MRC, NPP, S/R, Nav, A8,
E-Force Supercharged.
E-Ray is offline   Reply With Quote
Old 02-24-2017, 03:46 PM   #47
Lukemo
Lukemo's Avatar
Drives: '17 1LT RS V6 6M NPP
Originally Posted by E-Ray View Post
...Paired with small “spats” forward of the front tires...
"spats" is the official descriptor used by GM, then? lol I like it
Lukemo is offline   Reply With Quote
Old 04-25-2018, 06:02 PM   #48
musclecarsfan
Loves Big Block Power
Drives: 2016 Hyper Blue 2SS
I bought my car used and none of these are on my car. So they never got put on in PDI. Oh well
David
2016 Hyper Blue 2SS
musclecarsfan is offline   Reply With Quote
Old 01-28-2022, 06:04 PM   #49
SpeedyMcGrowley
SpeedyMcGrowley's Avatar
Drives: 2017 Camaro SS Fifty Anniversary
Part number
Anyone know the part number of these? Ripped one and have been searching high and low
SpeedyMcGrowley is offline   Reply With Quote
Old 01-28-2022, 06:26 PM   #50
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
hit up matt at wildhammer he can help you get them
Old 01-28-2022, 06:47 PM   #51
23408773 (left), 23408774 (right)
If you lived closer, I'd offer mine that I took off, but it's a $20 per piece item, you'll probably be better off getting new ones online.
Old 06-23-2022, 12:09 PM   #52
7Red7
7Red7's Avatar
Drives: 2016 Black Chevy Camaro 1LT V6
Front Air Deflector part numbers
23408773
Front Driver Side Tire Front Air Deflector
23408774
Passenger Side Front Tire Air Deflector
7Red7 is offline   Reply With Quote
Old 06-23-2022, 02:47 PM   #53
bigd1276
2017 HyperBlue 2SS
bigd1276's Avatar
Drives: 2017 HyperBlue Camaro 2SS
I replaced both of mine when I installed my splitter. They were in bad shape and for $22 a piece why not?
http://www.camaro5.com/forums/showthread.php?t=30755
2010 IBM 2LT RS......Traded for.....
2012 IBM 2SS RS......Traded for.....
2017 HBM 2SS
bigd1276 is offline   Reply With Quote
Old 06-23-2022, 03:32 PM   #54
Gen6cyl
Gen6cyl's Avatar
Drives: Chevy Camaro 2021 ,rs, v6, manual
I replaced one a while back,hit a possum.It was less than $30 at dealership.I though the 1le didn't have these because of their front splitter.
Gen6cyl is online now   Reply With Quote
Old 06-24-2022, 06:34 AM   #55
ctrlz
These air deflectors are there to reduce overall drag. The drag is induced by air interacting with rotating tire tread and causing all kinds of asymmetrical vortices which disrupt air flow, mainly under the car in this case.
These are found on many street cars for this exact purpose. Reduced drag leads to increased fuel economy. The impact of the deflectors will be relative to the overall drag coefficient of the body shape of the car. So the engineer saying the impact for a camaro is negligible below 125 mph may be spot on. The flip side of this is GM may have needed them to hit their fuel economy target for the CAFE standard. Fractional percentage gains count there.
Old 06-24-2022, 06:44 AM   #56
Nothing like an SS
Faster!!!
Nothing like an SS's Avatar
Drives: 2020 Camaro 1SS 1LE
1LE does not have these is correct
Nothing like an SS is offline   Reply With Quote
