09-06-2010, 08:47 PM | #29 |
Drives: 2012 Camaro RS, RX supercharged Join Date: Dec 2009
Here is a good link to understand diesel oil analysis:
http://www.polarislabs1.com/technical-bulletins.php |
06-13-2012, 07:35 PM | #30 | |
2010RS/SS RUMBLEBEE
Drives: Drives a 2010 2SS/RS Camaro Join Date: Aug 2010
Have you encountered a crankcase oil smell with the oil cap filter.I just installed mine and I am getting this nauseated oil smell plus soot residue on the rear splash guards/quarter panels and rear end. Is this common with this filter installed.
2010RS/SS RUMBLEBEE
06-13-2012, 08:44 PM | #31 | |
Drives: G5.R Join Date: Sep 2010
07-17-2012, 08:02 PM | #32 |
Drives: 10 SIM 2SS/RS LS3 Join Date: May 2008
took mine off a while back stinger bee!
5th Gen Camaros of the Carolinas SIM, 2SS/RS LS3 5/7/11 453.9 RWHP 427.5 RWTQ
VMS Stage 2.5 Comp Cams kit, Cold Air Inductions intake, ADM race scoop, DT 1 3/4" headers, Solo cats, 3" Magnaflow catback, Pypes cutouts, HP tune, H&R SuperSport springs, Eibach sways/spacers, TexasSpeed UD pulley, LSR tensioner pulley, Barton shifter, skip shift eliminator, powder-coated calipers, R1 concept rotors, StopTech pads, Granatelli wires, Lloyds mats, tint, AAC afterburner taillamps, AAC scanner/sidemarkers, SRP pedals, custom engine cover, black bowties, Ridergraphix hood spears.... |
08-01-2012, 01:36 AM | #33 |
HT5 COTW 1/21/13
Drives: 2010 Camaro Inferno 2SS RS 6M Join Date: Apr 2011
Wow a lot of good info in this thread
08-01-2012, 04:11 AM | #34 |
This kind of ties into a Catch Can. I bought an RX CC and was thinking about doing this breather, but from hearing people on this forum and one of the guys in our club who had their rear main seal start to leak after installing the breather has made me think twice about getting it. However, I am not sure if RX has re-engineered the valves in the breather or CC to prevent this from occuring.
2011 Camaro 2SS/RS, Circle D 3200, ADM Transmission Cooler, BTR Valvetrain, Cam Motion .621 .595 228/244 113+4, ARH 1 7/8 full exhaust, Cold Air Inductions, Katech C5R TC, Melling HV, BTR SLR lifters, Trunion Upgrade, LS2 Dampner, LS9 head gaskets, Bo White PTB, MM can, GFX, Subs, B&M Deep transmission pan,
Holley fuel rail, Proform valve covers, relocated coil packs |
08-01-2012, 07:13 AM | #35 |
Drives: 2010 Camaro SS LS3 Join Date: Sep 2010
You really should check your fuel trims as well. Even with the check valve, it does change them by a few percent.
She is only memory now. |
08-01-2012, 10:21 AM | #36 | |
COTW 5/27/13
622RWHP/512FTLBS on 91 octane 2.9l Whipple 4" pulley. Vengance VRSP3 cam. Lots of BMR & AAC. Body work by Gary's Customz. Nic D tuned My build thread |
08-01-2012, 10:34 AM | #37 |
Drives: 2010 Camaro 2SS/RS White S/C Join Date: Aug 2010
IMO, it just looks cool, that's it.
"It does not matter if you win or loose, what matters is if I win" Carl Fogarty |
08-01-2012, 01:56 PM | #38 | |
Perpetual Order
Drives: indeed Join Date: Jun 2012
08-01-2012, 05:34 PM | #39 |
if installed correctly there can be no leaks......with over 10,000 of these sold and installed in every type of application possible we have no issues, but some have hooked them up backwards and had issues.
With a V8 you may need to T both the valley cover vent and the rear of the drivers side valve cover if the fixed orfices have become clogged due to gunk build-up. And yes, the RX flow controlling checkvalved breather will still alter the short term fuel trims a few percent but way within the acceptable parameters where an open breather will skew all over the place. |
Similar Threads | ||||
Thread | Thread Starter | Forum | Replies | Last Post |
L99 Lifters | Ohten | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 25 | 06-29-2010 09:33 AM |
Dealer installed Engine Cover | BMBB5 | 5th Gen Camaro SS LS LT General Discussions | 18 | 04-22-2010 09:09 AM |
AFM: how does it works? | tommygun6644 | 5th Gen Camaro SS LS LT General Discussions | 9 | 02-28-2010 03:36 PM |
Piston to Valve Clearance? | My First Camaro! | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 3 | 08-18-2009 07:26 PM |
Camaro ls3 news...true or false? | Dark Knight | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 74 | 06-05-2008 05:29 PM |
