10-31-2018, 09:29 PM | #29 |
You're going to fall in love with that A10 and the Performance Shifting algorithm. It will blow you away on the track.
Hopefully your wife doesn't do what my wife did. I went for the auto thinking she would get more left seat time and I can't remember her ever driving it. But you'll find this car is an easy daily driver. Congrats and welcome to the forum. |
10-31-2018, 09:38 PM | #30 | |
All I have left now is swapping to DOT4 brake fluid. |
10-31-2018, 09:58 PM | #31 | |
Drives: 2019 ZL1 Join Date: Sep 2018
11-01-2018, 06:01 AM | #32 | |
Drives: 2019 ZL1 1LE A10 Join Date: Jan 2015
I came from a manual car and now, in an A10 and frequent COTA about 5-6 times a year. I do not, in any way, miss a manual, especially when I'm driving on MOPAC to work. A10 is quick on COTA and very consistent.
I've gone slightly quicker than this lap, but you get the idea...
Ryker #29
2019 ZL1 1LE A10 2015 Z/28 #809 |
11-01-2018, 06:28 AM | #33 |
Drives: '16 Camaro SS 6 spd manual transm. Join Date: Aug 2012
Vipers and specially the ACR model are very special cars, i would say on the exotic car league, supreme at the track and to look at but a torture chamber and impractical for a DD car, I think you would love the Camaro ZL1, I see many happy customers driving DD their Camaros. I also would one day change my nice looking Stingray Z51 for a 6th. Gen SS 1LE or ZL1, probably I would miss only the looks of my Stingray but I should also enjoy my Camaro. I had a great driving experience with my prior 5th gen Camaro ZL1, so I expect much better with the 6th. gen. Go for it.
'16 Camaro SS
Prior cars: '14 Corvette C7 Stingray Z51 '14 Camaro ZL1 w/. Recaro seats '11 Mustang GT 5.0 w. track package '02 Porsche 911 Carrera '05 Infiniti G35 coupe sport |
11-01-2018, 07:36 AM | #34 | |
Drives: 2017 ZL1 Camaro Join Date: May 2018
Any new engine I have built or have had built over the years always got the oil changed after a few hundred miles. The filter would be cut open and inspected, which will tell you a lot about what's going on inside and engine. I also carry over this mindset to any new vehicle. I changed the oil on my 17 ZL1 at 700 miles, 18 Silverado at 900 miles and my wife's 18 Acadia at 1000 miles. When I changed the oil in all of these vehicles I cut the oil filter open and inspect the filtering elements and have found a noticeable about of aluminum casting flash and assembly lube. While the oil looks great and the oil filter is doing it's job all should be fine. For me personally, I don't like the idea of relying on my filter to contain all these contaminants (which is a lot more than what is seen on any normal oil change on a healthy engine) for the next few thousand miles or when ever the recommended first scheduled oil change is. It gives me peace of mind to remove the filter and oil from the new engine for fresh. I do the same procedure on the second oil change and has always shown very clean oil and filter. At this point I start doing normal oil change intervals. OP, I wouldn't be overly concerned about going to 1000 miles but I would make it a point to have it changed ASAP once you arrive home. |
11-01-2018, 11:27 AM | #35 | ||
Nice! that's faster then I went in the Viper with traffic, I never got a clean lap and didn't get under 2:30's. I was hitting about the same MPH on the back stretch too! Can't wait! Did you change the brake pads for the track? The pads on the Viper faded and I had to go with aftermarket. |
11-01-2018, 11:29 AM | #36 | |
Thanks, I've already order the oil. I sure as hell didn't want to change the oil in Dallas on the way back! I also plan on sending the oil to Blackstone. |
11-01-2018, 12:00 PM | #37 | |
Drives: 2019 Silverado Z71 6.2L A10 Join Date: Mar 2017
Current ride
2019 Silverado Z71 LTZ 6.2L L87 425hp A10, 4 inch BDS Lift with Fox Factory Race 2.5 Coilovers, Borla Cat back (15HP bump), BFG KM3's 33's. Past Rides 2017 M6 Camaro ZL1 Hyper Blue 2016 M6 GT350 White with blue strips 2014 M6 Mustang GT Premium Track Pack Ruby Red 2012 M6 M3 Melbourne Red Metallic |
11-01-2018, 01:12 PM | #38 | |
- Upgrade the brake pads for COTA! I use Colbalt's offering for our cars, not cheap about $1K a set. - Track alignment (GM has a PDF, the dealers know how to align) - Order a HANS Hybrid-S and an SA2015 helmet because this shit is as fast as the Viper and in case there is a problem on T10 or T19/T20 you will see another track day.
Ryker #29
11-01-2018, 01:25 PM | #39 |
Go big or go home... come over to Houston and run MSR with us Dec 16th and then work up to COTA.
11-01-2018, 01:53 PM | #40 | |
Like I said, doing the early changes IS pampering the car. These new engines are built much cleaner and tighter then they used to be and run on great oil out of the box. However, after seeing what the oil looked like, I'd rather just change it because the cost is paltry and knowing the car is in as best shape as possible is worth it to me. |
11-01-2018, 04:06 PM | #41 |
11-01-2018, 04:09 PM | #42 | |
I did use SRF for the Viper, already have a helmet (no HANS) and good to know about the pads. Do you swap out street pads and race pads or leave the Colbalt's in? Also, I was about to order PFC pads for the Viper, is anyone running those? Last edited by esm; 11-01-2018 at 06:51 PM. |
