08-02-2017, 01:28 PM | #1 |
Drives: Kubota 2640, 83 BMW R-65, 2017 1 SS Join Date: Nov 2016
Rear diff lube? GM, Amsoil, Royal Purple?
Going to change the rear differential lube as soon as I figure out WHAT to stick in there.
I know the "WHAT oil should I use?" posts turn into a goat rope in short order. Not only here , but on the gun forums too. Lots of opinions. The GM #88862624 has the ADDITIVE already mixed in. Is there definitive proof that Royal Purple or the Amsoil lube is truly BETTER? |
08-02-2017, 01:37 PM | #2 |
Drives: Sold Join Date: Mar 2017
I'm going to run the ACDelco stuff until I have reason otherwise. Too many complaints about the other stuff out there with regard to groaning starting up after a bit. Already had to deal with incessant groaning with the 2016 SS before that was all sorted out. I don't want that with the ZL1.
08-06-2017, 09:59 PM | #3 |
Drives: 2017 2ss, m6 Join Date: Jan 2017
Probably no proof to be honest. The RP that came out of mine after 6 long track days still looked great for what it's worth. Probably had 18-20 wide open hours on it with minimal cool down periods and 8500 street miles.
08-07-2017, 08:54 PM | #4 |
Drives: 2016 2SS, Summit White, A8, NPP Join Date: Apr 2013
My rear diff had the groan and I changed mine with the GM with additive and groan is gone so far, been around 1200 miles.
08-07-2017, 08:58 PM | #5 |
Drives: 16' 2SS M6 Join Date: Feb 2010
I'd stick to the GM w/ additive stuff......no groan for my diff. You may risk groan with other brands.
08-07-2017, 10:11 PM | #6 |
Thanks Gentleman....got the GM stuff....Going to change it tomorrow.
08-09-2017, 07:16 PM | #7 |
Changed out the rear diff fluid and was somewhat surprised how little ANYTHING I had in the oil...short of some black dust on the weak , drain plug magnet. It was sort of grey but no metal of any kind.
Installed the Gold Plug, magnetic plug when I refilled. |
08-09-2017, 10:00 PM | #8 | |
I didn't hear the or feel the groan this morning, so here's hoping the issue is gone @ 3300 miles. |
08-10-2017, 11:26 AM | #9 | |
My refill was to get the better, magnetic plug installed and to simply look at the oil in there. I had NO issues with groaning or noise. I hope Your groaning issue is gone. It's a nice feeling when a guy can actually FIX something. Good Luck. |
