09-25-2018, 02:53 PM | #15 |
Bannable
Drone is actual cabin pressure. Like a subwoofer. It's unbearable if there is enough of it. Some cars suffer from it a lot more than others. C6 corvette autos were EXTREMELY sensitive to it. I agree that a lot of people confuse being able to "hear" the exhaust with "drone". But again, the amount of drone one can tolerate is subjective.
One must forego the self to attain total spiritual creaminess, and avoid the chewy chunks of degradation
2017 ZL1 A10 - Hyper Blue Metallic Rotofab CAI, TM ported TB, AWE non res touring catback with PLP's |
09-25-2018, 03:00 PM | #16 | |
Drives: 2017 Camaro ZL1 Join Date: Aug 2018
09-25-2018, 03:05 PM | #17 | |
Bannable
Sorry to derail. Just trying to expand horizons while we are on the topic
09-25-2018, 03:05 PM | #18 | |
Drives: 22' Porsche PDK GT4 Join Date: Mar 2018
If you are buying an exhaust system, you WANT to hear it in the cabin more than stock, otherwise what is the point, why buy something for sound that only those outside can hear. You just don't want that Sub woofer frequency drone part.
Current:
22' Porsche PDK GT4 (MCS 2-way remote dampers) Previous: 18' NFG 2SS 1LE (ZL1 1LE solid rear cradle bushings & Corsa Exhaust) 16' F80 M3 (Ohlin R/T Coilovers) 13' Audi TTRS (APR Stage 1, MSS Springs) 09' C6 Z06 08' E90 M3 06' 335i (KW V2 Coilovers) 03' C5 Z06 |
09-25-2018, 03:24 PM | #19 | |
Drives: 1LE Join Date: Sep 2018
Edit (just for the record): you're very correct in stating drone is a subjective matter. Luckily we do not rely on our human makeup to determine whether there's drone with X and Z design on each platform we develop for, rather we take in-depth sound recordings which undergo painstaking analysis (radical science) to determine which frequencies we need to remove with 180 Technology®. Fun stuff. Last edited by Josh/AWE; 09-25-2018 at 03:50 PM. |
09-25-2018, 03:40 PM | #20 | |||
Drives: Grandad's C2 L89 Join Date: May 2017
2018 ZL1 1LE sw/PDR
09-25-2018, 03:40 PM | #21 |
Drives: C7 Z06 Join Date: Jun 2018
Just take my money already
09-25-2018, 04:18 PM | #22 | |
Josh, I'm assuming that as AWE gets closer to release, that emitted dB levels will be posted? Am I correct in assuming that your performance link pipes will delete the secondary cats? I believe that PLPs with 180 tech (touring) will suit my needs perfectly, and preserve my relationships with the neighbors. Do PLPs connect to mid pipes via flange or slip connection? Sorry for so many questions. Thanks in advance.
2018 ZL1 1LE sw/PDR
09-25-2018, 04:45 PM | #23 | |
You are correct about the PLPs. They bridge the gap between the primary catalysts and the CBE. The PLPs certainly give an extra dose in the volume department. If it were me, I would tango with the Touring Edition first and then add the PLPs. The decision on approach is yours to make, of course |
09-25-2018, 06:38 PM | #24 |
2018 Garnet Red ZL1 conve
Drives: 2013 & 2018 ZL1 vert Join Date: May 2009
Make sure you make a complete system for the vert!
Build Thread: 2018 ZL1 Vert Purchased (Overpar73)
09-25-2018, 07:45 PM | #25 |
Drives: '17 ZL1 Join Date: Jul 2016
Any chance the design maintains proper airflow under the car? Most aftermarket exhausts turn the rear fascia into a parachute.
09-25-2018, 08:04 PM | #26 |
Drives: Chevrolet Camaro SS Join Date: Mar 2015
Does this still use the NPP?
09-25-2018, 08:55 PM | #27 |
Drives: SS-6-SPD Join Date: Jan 2017
4.5” exhaust tip option?
09-25-2018, 08:59 PM | #28 | |
Not sure what we can do there other than some form of aftermarket diffuser. No NPP. 4.5" polished or black.
2018 ZL1 1LE sw/PDR
