Old 06-25-2018, 10:48 AM   #29
RSFR
RSFR's Avatar
Drives: ZL1
Originally Posted by Try2paz View Post
No disrespect but you're all over the track.
You appear to be getting the car out of control to hit the rumble strips? You need to leave yourself some some room you're not competitively racing and you're up on top of them most of the time. You're lucky you didn't drop a tire into the grass and put that car on it's roof.
I'm not trying to bash you simply giving you a bit of warning it can happen quickly and I've seen it happen.
Are you leaving traction control on? I bet the ECU is freaking out hitting those rumble strips that hard with you jerking the wheel.
You're supposed to use the whole track, including the strips.
I'm not at all out of control.
This was a competition called Octane Time Attack. I placed 3rd overall for the championship for fastest lap times and won the championship for most consistent driver.
ECU is always in PTM race.
RSFR is offline   Reply With Quote
Old 06-25-2018, 11:37 AM   #30
Mark R
Drives: 2018 ZL-1
You were giving it the Beans. Nice driving!
I can see why the bag blew, based on some videos I've seen explaining how these systems work. It sensed incipient rollover, and the system worked as designed.
YOU didn't tip it, but if this kind of vehicle movement happened anywhere but a racetrack, in the average person's hands, the car would have probably rolled, and the bag would be considered correctly deployed.
Glad you are OK.
Mark R.
Albuquerque, NM
Old 06-25-2018, 11:48 AM   #31
7WSM
7WSM's Avatar
Drives: 2017 ZL1 A10
Originally Posted by rootus View Post
Because the pre-tensioners fired on all the belts? That does sound plausible. Ugh. $$
Yep, that is the exact reason. At least every single time I have seen one where all the seatbelts are locked up, you have to replace the retractor assemblies and the SDM, along with all the airbags.
7WSM is offline   Reply With Quote
Old 06-25-2018, 11:55 AM   #32
Squatch
Camaro pilot
Squatch's Avatar
Drives: 69 Camaro, 2014 ZL1
I wish there was a way to disable air bags, I hate them.
2014 ZL1 Camaro
1969 Camaro
Squatch is offline   Reply With Quote
Old 06-25-2018, 12:01 PM   #33
ChevyRules
Drives: 2021 Tesla Model 3 LR
Until they save your life and/or reduce the severity of the injuries you sustained in a crash.... Or better yet... a loved one.
ChevyRules is offline   Reply With Quote
Old 06-25-2018, 12:01 PM   #34
1970judge
Drives: 2015 Z/28, 2007 HHR
Your 3 runs back to back to back...that third run you ate up a lot more curb. The car was wheel hopping badly.
1970judge is offline   Reply With Quote
Old 06-25-2018, 12:04 PM   #35
Vtor_ZL1
Who Needs to KNOW?
Vtor_ZL1's Avatar
Drives: 18 ZLE
Looking at video frame by frame ( , and . on youtube), its seems pretty clear clear car goes off the curb into the grass and when it comes back over curbing, there is big jolt, you can see infield grass and rear end catches and tries to toss the car. Infield looks well kept, I've seen track where there is crazy ruts just off the track surface.
Garage door opener falls down - there reason loose items dont belong in a car on track day - they become projectiles.
3 Laps, same section of track.
Lap 1 and 2 - on the curbing, Lap 3 - in the grass!
Definitely a code brown!
ing for grip.
http://www.motorsportsne.com/
Old 06-25-2018, 12:30 PM   #36
thescreensavers
thescreensavers's Avatar
Drives: SW 1SS 1LE / Jeep XJ
Originally Posted by hashtag View Post
Then it does not have one for ZL1 w/ Recaro’s or SS w/ Recaro option. By law there has to be a label on the seat area where the SRS is & it appears the Recaros seats do not have airbag’s.
The Recaros are OEM seats wrapped in "Recaro" material. According to the factory service manuals the OEM seats have airbags.
OP let us know how the dealer goes!
thescreensavers is offline   Reply With Quote
Old 06-25-2018, 12:30 PM   #37
RSFR
RSFR's Avatar
Drives: ZL1
Yes, I took more curbing on the last lap trying to get a fast lap. You can see in the pictures you posted, there is a brown patch on the inside of the curb that is just dirt. This is where they filled a rut from cars driving over it. I can tell you people have taken my exact line through there and haven't had airbags deploy. You can also see in the video on the other corners where I hit the grass cutting the corner, but no airbag deployment. All the fast guys get in the grass trying to shave a hundredth of a second off their time. I was a tad ambitious going into that last turn and was carrying more speed than usual and I guess that was enough to trip the sensor.
Old 06-25-2018, 01:57 PM   #38
Sleeks
Drives: None
Originally Posted by Badgerbimmer View Post
At all the track days at Road America everyone is warned to try to stay off the corner rumble strips as they are big enough to set off airbags. Always thought that was kinda BS. Well now we know that its not BS!
^This
-Brian
Hyper Blue 1SS / 1LE
Sleeks is offline   Reply With Quote
Old 06-25-2018, 02:14 PM   #39
GearheadSS
GearheadSS's Avatar
Drives: 23 LT1/22 Colorado TB/69 Chevelle
I'm glad you're ok and that the damage to the car wasn't worse. It'll be easy to replace the airbags and seatbelts and then be back at it again.
Old 06-25-2018, 02:54 PM   #40
hashtag
hashtag's Avatar
Drives: 2018 ZL1 A10/2018 GT350R #JR603
No label no Air Bag. Our seats do not have them.
2018GT350R+2018 ZL1 "Red Hot" A10 w/ PDR, Nav, Carbon Fiber Hood insert, Carbon Fiber Dash Insert, Carbon Fiber Fuel Dior & Sun Roof. T/M T-Body, Roto Fab & Borla S Type.
hashtag is offline   Reply With Quote
Old 06-25-2018, 05:16 PM   #41
Mr. Meh
Drives: Sold
Pretty sure I blew my drivers side air bag. Had to get a full upper and cover plus the bag.
EDIT. Found it
As you can see. Deployed air bag, from the factory Recaro seats in a Gen6 ZL1.
Mr. Meh is offline   Reply With Quote
Old 06-25-2018, 06:36 PM   #42
hashtag
hashtag's Avatar
EDIT. Found it
I stand corrected. Damn
Out of curiosity may I ask how much that was ?
