12-18-2020, 11:46 AM | #1 |
'20 1LE torque converters
So, I'm applying 850bhp to a stock converter designed for 650bhp in a car that already has too much low gear. I made a bad traction situation worse.
Does anyone sell a tighter converter for this baby?
'20 ZL1 1LE A10,
12-19-2020, 07:20 PM | #2 |
2019 ZL1 1LE MY GOON
Drives: 1980 Z28 Big Red. Join Date: Dec 2018
Try maybe Circle D converters.
12-20-2020, 06:23 AM | #3 |
Remember how we've told you that the 2020+ auto transmission cannot be tuned? Because the T93 TCM is locked and they don't expect to unlock them either? This means that you cannot re-tune your car for an aftermarket torque converter.
12-20-2020, 07:41 AM | #4 |
We can't change the TCM tables but we can adjust timing in the low to midrange part of the timing map to accommodate or adjust for, in my case, the tighter converter I need.
'20 ZL1 1LE A10,
