11-13-2016, 01:18 PM | #1 |
Drives: '17 1SS 1LE & '15 Corvette Z06 Join Date: May 2009
'17 1LE Wheel Sizes and Offsets
Trying to ascertain if the MRR M228's from our 2015 will work for winter rubber.
What about the MRR stems clearing the calipers? I realize rear tire size is up from 285 to 305's. Last edited by bub; 11-13-2016 at 01:32 PM. |
11-14-2016, 08:11 AM | #2 | |
Drives: Summit White 2016 2SS Join Date: Jan 2015
R 20x11 43mm offset. 305/30/20
2015 1LE sold
2016 2SS sold |
02-19-2017, 06:55 AM | #3 |
Drives: 2017 1le current /2015 2ss 1le sold Join Date: Jan 2016
So I believe the answer is yes? Anybody try this yet?
2017 1LE Hyper Blue
02-19-2017, 08:00 AM | #4 |
Drives: 2017 HBM SS 1LE Join Date: Jan 2017
02-19-2017, 08:10 AM | #5 | |
2017 1LE Hyper Blue
02-19-2017, 08:34 AM | #6 |
Couldnt tell ya that....I just remembered readIMG this thread back a few days ago and found it for you
02-19-2017, 08:48 AM | #7 |
Thanks for the post.. it seems 2 tpms are used 315 or 433 frequency..
2017 1LE Hyper Blue
02-19-2017, 08:49 AM | #8 |
Thanks for the post.. it seems 2 tpms are used 315 or 433 frequency..build sheet on sticker in trunk should clarify.
2017 1LE Hyper Blue
02-19-2017, 11:47 AM | #9 |
Drives: 2022 1SS 1LE A10 BCD WCT+PDR Join Date: Mar 2008
I thought the front offset on the 6th Gen 1LE was 20mm
02-19-2017, 12:03 PM | #10 |
Drives: 2017 1SS/1LE Join Date: Sep 2016
02-19-2017, 12:12 PM | #11 |
That's 3/16th of an inch... sure doesn't seem like it would impact much unless it rubs or can't clear the calipers
2017 1LE Hyper Blue
02-19-2017, 12:53 PM | #12 |
We're not arguing fitment. We're just stating that the OEM size/offset of the 1SS/1LE wheels are 20x10 +20 and 20x11 +43, not what is stated above.
02-19-2017, 01:56 PM | #13 |
Drives: 2017 Camaro 1SS 1LE Join Date: Jan 2017
If I was getting a set of 19s and wanted to keep the exact same tire setup on my 1LE would I be looking for the exact same offsets / widths in 19?
19" 10 - 20 for the front 19" 11 - 43 for the rear? |
02-19-2017, 02:22 PM | #14 |
Nobody is arguing, just want to make sure the correct info is out there, that's all
millimeters matter
