10-05-2017, 04:09 PM | #1 |
Drives: 2017 camaro 1ss 6sp manual Join Date: Nov 2016
E85 question
hey all multiple questions on e85.
before we start my search button isn't working if you have a link to these answers just post that. 1. what all is needed in changing to e85 car is all stock except headers and no cats. 2. live in michigan it gets very cold car is driven all year unless there's snow I heard cold will cause problems when you have e85. 3. when you run e85 can you switch back to 93 octane like a flex fuel car just run it empty then fill. thank you for help |
10-05-2017, 04:32 PM | #2 |
Drives: 2017 Camaro SS M6 Join Date: Apr 2017
If you go flex-fuel, which there's lots of kits out there for our car, then yes you can switch from e85 or 93 whenever you'd like or run both. Regarding not driving your car when it has e85 sitting, generally if it's sitting for more than a month it can cause a problem, but others say they haven't had a problem with e85 sitting in the tank for months.
2017 Camaro SS - Kooks Long Tube Headers 1-7/8th - EFI Flex Fuel Kit - Megan Racing Coilovers - FORGESTAR F14's 20x9.5 & 20x11
10-05-2017, 04:57 PM | #3 |
Drives: 2016 1SS D1SC Methfed Lowered Wrapd Join Date: Apr 2016
All you need is a flexfuel kit (like EFI or skidmarkperf) and a retune. I would find your friendly local LT1 familiar tuner and see which one he likes working with.
//2016 1SS M6 D1SC Upgraded IC 4.25 Pulley//
// Alky Control Meth Kit running 100% methanol // (purchased from JDP, installed by True Bliss Customs, tuned by NewEraPerformance in Augora Hills) // 3M/Gotch Design Sponsored Gloss Deep Space Colorshift Wrap // |
10-05-2017, 06:31 PM | #4 |
Drives: 2010 camaro RS,2017 camaro 1Le Join Date: Mar 2016
I would be more concerned with winter e85 mixes then I would the actual could having an effect on the car
2017 camaro 1le
ROTO fab, Ported MSD, Ported 95mm tb, 2in TSP catless longtubes, flowmaster x-pipe, flowmaster American thunder npp, flex fuel, |
10-05-2017, 07:06 PM | #5 |
would running the flex fuel so the same performance as just running e85 all the time.
baker...what do you mean more worried about mixes. is it like 93 where they have a winter and summer mix |
10-05-2017, 07:19 PM | #6 |
If you mean flex fuel as in 93 and e85, then no, performance is not the same as just e85. But if you mean running the flex fuel sensor and only e85 in the tank, then yes, same performance.
10-05-2017, 07:27 PM | #7 |
I meant straight e85. i was wondering if having the flex running would be crappier performance over just e85 only tune.
10-05-2017, 07:44 PM | #8 | |
Drives: 2016 Camaro SS / 1SS Join Date: Nov 2016
The ECU in the Camaro has a table that has a blend factor for the different amounts of ethanol sensed in the fuel line. There is a separate "adder" table present in the computer that is used to add spark advance to the normal gasoline spark table. So for example when the sensor sees 50% ethanol in the fuel, it will blend the two tables values. |
10-05-2017, 08:09 PM | #9 |
Drives: 2016 Hyper Blue 1SS Join Date: Jul 2015
Other than the price of e85, there is no benefit of running it for daily driving use to me. I run 93 up until i know im headed to a track then i run e85 for about two fillups to flush all the 93 out my car. This picture is with one gallon of 93 in my tank and 16 gallons of e85, next tine i fill up i should be arouns e80. Most of the e85 around here measures out to only e79
1ss/Auto-Hyper Blue
acs carbon flash spoiler, bmr springs, gm clear tails. Texas speed cam, 223/227 .635/.635 116 LSA, Kooks Long Tube Headers with green cats, MSD Atomic Air Force Intake, CAI Cold Air Intake, QTP cutouts. 503 hp Best so far 11.5 at 123 with a 1.83 60ft. BMR lower and upper trailing arms and upper control arms,E85 DELIVERED 12/29/15 http://youtube.com/bybcous " no talking only racing on my youtube" |
10-05-2017, 09:36 PM | #10 |
When your car is tuned with the flex fuel sensor, they do a 93 tune first, then they do an e85 tune only. So that way the parameters are set to either 93 only, e85 only, or a mix of both. So no, running the flex fuel sensor won't cost you any gains compared to an e85 tune only.
10-05-2017, 09:36 PM | #11 | |
Drives: 2016 1ss m6 Camaro Join Date: Jul 2016
2016 camaro 1ss,m6-npp,tsp longtubes,no cats,e85,tuned by rpm motorsports(451hp/467tq),
17"race stars drag pack,bmr upper and lower trailing arms,bmr upper control arms,bmr front cradle brace,gforce outlaw axles/driveshaft,lnf 2step. Best 1/4 mile of 11.2@122mph |
10-05-2017, 09:44 PM | #12 |
You def are not lying! But it's either frequent stops at the gas station or constantly cleaning your exhaust tips lmao.
10-05-2017, 11:53 PM | #13 | |
Out of curiosity, what are you paying for E85 and what is the price of 93 Octane in your area? Note, my 83% efficiency factor is based on me averaging 20.5MPG for 4,000 plus miles on premium unleaded. I have been burning E85 for 400 miles so far and am averaging 17.2 MPG. So 17.2 / 20.5 = 0.839. |
10-06-2017, 12:11 PM | #14 |
I just want to say thanks to all. e85 is usually around a dollar cheaper by me and a lot of stations sell now. but I was told e85 is not friendly with the cold which is why I am so curious on the flex fuel.
