07-25-2016, 02:43 PM | #29 | |
Too Many Great Choices
Drives: Grand Sport/Z07 Join Date: Jun 2009
Very doubtful.
07-26-2016, 03:55 PM | #30 | |
"M1SS1LE"
Drives: 2017 SS 1LE Join Date: Dec 2015
MJK3888 Instagram Link
07-26-2016, 05:26 PM | #31 | |
07-26-2016, 09:43 PM | #32 | |
Drives: 14 Silverado LTZ Z71, 16 Camaro SS Join Date: Nov 2009
The extra 200hp when available will be partially negated by the extra 200lbs the zl1 will weigh over a 1le. On tighter courses the 1le might run right with a zl1. The grand sport should be quite a bit quicker than a z51 which is pretty close to a 1le. Which btw they have not been tested same track same day same driver so its a guess. I don't see the zl1 being faster than the GS. Only the z28. Looking back at last gen the zl1 and 1le had similar handling with just a difference in power which will help on some tracks. I see the zl1 being a bit quicker than a 1le and z51 but not enough to beat a GS. A z28 should do it though. I don't think the zl1 will beat a 350r on most courses either. Its not a hardcore track focused car. Its an all around performer. |
07-26-2016, 11:32 PM | #33 |
SABIO
Z/28 , zo6 , ZL1 , 1LE then the rest.
07-27-2016, 01:23 AM | #34 |
Drives: Want a gen 6 Join Date: Jan 2013
I think the GS will beat the ZL1 around a track by maybe a half a second or more. It's using the z06 chassis, suspension and rubber setup. The cornering grip will make the difference over the ZL1. It won't be huge though, and the ZL1 will be a much better street car in my opinion, better on the 1/4 mile too. The 0-60 will be essentially the same, with the ZL1 just 1/10th or two faster with like transmissions.
07-27-2016, 08:19 AM | #35 | |||||
"M1SS1LE"
07-27-2016, 08:40 AM | #36 |
"M1SS1LE"
To me this implys the 1LE is very close to the Z/28. FYI this is not the source of my info.
07-27-2016, 09:39 AM | #37 |
Drives: 21 Bronco Join Date: Jun 2012
No way.
The top Corvette will always outperform the top Camaro. Z06 Z/28 Grand Sport ZL1 1LE |
07-27-2016, 10:15 AM | #38 | |
Drives: 2014 2LS (traded in) 2015 1SS 1LE Join Date: Apr 2015
But you're probably right.
07-27-2016, 10:34 AM | #39 | |
Drives: 2015 SS 1LE Red Hot, 1970 Chevelle Join Date: Apr 2012
If the Z/28 doesn't gain a bunch of weight, it can be within 200 lbs of the Z06, which is pretty insane.
07-27-2016, 11:02 AM | #40 | |
07-27-2016, 12:25 PM | #41 |
Mjk3888,
Randy ran the Stingray at LS to a: 31. Chevrolet Corvette Stingray Randy Pobst 1:38.28 Based on your comments (hmmm) let's say the 1LE ran a high 1:38 to 1:39, my guess is the Grand Sport Z07 will nock 2.5 - 3.0 seconds off the Stingray at LS. The ZL1 probably another 2 seconds shaved from the 1LE for a 1:37. As mentioned previously the ZR1 and Grand Sport Z07 are very very close in time around Milford. Here is the LS time for Randy in the ZR1, 8. Chevrolet Corvette ZR1 Randy Pobst 1:33.70
07-27-2016, 01:07 PM | #42 |
For reference, Randy's time in the CTS-V at LS; 32. Cadillac CTS-V (Mk III) Randy Pobst 1:38.52
I believe it's a couple hundred pounds more than the expected weight of the ZL1.
