01-23-2023, 10:53 AM | #29 | |
01-23-2023, 10:57 AM | #30 |
I like the cam lope as long as off idle light load drivability is there . But maybe you’re right a smooth idle cam with less overlap might be the key to keeping the sound in line. For some reason that video had a farm truck tone. Not sure what was going on there
The jre or katech lt1 torquer might be an option
01-23-2023, 04:12 PM | #31 |
Drives: 2022 Camaro LT1 M6 Recaro NPP Join Date: Nov 2021
Can anyone confirm or disprove if the 8 non dod lifters in a LT1 are LS7 lifters. Just curious.
2022 LT1 M6 Recaro Red Hot NPP red calipers red seat belts GM short throw shifter GM strut tower brace GM CAI Long tube headers YYZ springs LT2 intake E85 MightyMouse catch can
1992 RS 5.0 5-speed, 1995 Z28 Auto, 1999 WS6, 2007 Trailblazer SS. |
01-23-2023, 07:21 PM | #32 | |
2016 NFG 1SS A8
01-24-2023, 06:29 PM | #33 | |
Drives: like an old lady Join Date: Jun 2012
01-24-2023, 08:22 PM | #34 |
i had planned on using this camshaft in my camaro. with no rear gear options and 3600+ lb i think it would work great in a street car.
i sold the camaro and moved to a lighter chassis, still m6, but with rear gear options. i'll still stick with a btr camshaft but go bigger.
01-25-2023, 05:37 AM | #35 |
Can’t believe you sold it but glad u still have a v8 in your life..and sounds like a fun project
It’s down to a katech torquer and the 220. I’m 99% on the 220. The timing should be for next fall tho but I’m going to start getting parts
01-25-2023, 08:21 AM | #36 |
look at the dyno graph on the v220...still 400+ ft/lbs at 2k rpm vs the v230 which is down 50ft lbs at 2k... most cams around 220 intake duration on a 6.2 should still offer close to stock like tip in throttle response since they don't give up much if any low-speed torque. Once you get mid upper 220's then you start to give up low speed torque for more mid upper. Then you want gears/converter/compression to help keep it from being a turd down low.
2016 NFG 1SS A8
01-28-2023, 02:47 PM | #37 |
Drives: SS 6 speed of course Join Date: Jan 2016
I had cam motion make me a sub .600 lift cam with gentle ramps, it has been many years now and I just added rocker studs, cleaned the intake ports, check cam wear and all looks good. I'm sure I gave up say 15 HP on this street lift, street ramp cam, but the ability to do 100,000 miles on my engine was far more important. It has been years now but if you guys do a search, I stated WAY back then that the ramp profiles were all wrong on these high lift performance cams and it had NOTHING to do with the valve seat, valve head (in some cases), or even the lifter (though I would recommend Johnsons).
01-29-2023, 12:56 AM | #38 |
Drives: Camaro 2ss Join Date: Jun 2020
I’m looking at getting the El-C7 cam from Texas speed. You say that their cams beat up the valve seats. Are they are stock valve seats?
