Old 01-29-2023, 11:24 AM   #29
Casper the friendly G
Drives: 17' Chevy Kamaro SS 6 speed
Different intake and exhaust manifolds
The exhaust on the camaro is a shorty header.
Casper the friendly G is offline   Reply With Quote
Old 01-29-2023, 11:39 AM   #30
Originally Posted by UnknownJinX View Post
I think it would be closer to a C7 Corvette engine, which shares the same name. The base Stingray makes the same amount of power and 5 lb-ft more of peak torque.
But even then, they have differences such as different exhaust manifold, where the C7 has a basic 4-to-1 collector while Camaro has a tri-Y design, probably for better scavenging. According to GM, 20 percent of the components of the Camaro LT1 is specific to it.
https://media.gm.com/media/us/en/gm/...wertrains.html
Please include a pic of the Silverado 6.2
Old 01-29-2023, 02:38 PM   #31
Ventmaster
Ventmaster's Avatar
Drives: 2017 1SS 6spd
Originally Posted by Haans249 View Post
I'm bumping this to the Top.
I'm considering replacing my LT1 in my camaro that is damaged beyond repair with the L86.
From what I've read, all the internals are exactly the same, even down to the cam timings (https://www.hotrod.com/articles/clos...evy-lt-engine/).
However, I have seen other posts mention that the oiling is different, but no one can provide any clarity on what exactly that means.
Does the L86 share the same piston oil squirters as the LT1?
Aside from all of the external items I can take off my broke LT1 and swap to the L86 (oil pan/valve covers/I have headers/intake/tb/etc...) here are the items i'd like to verify:
1) HPFP and Injectors are different between the L86 and LT1?
2) Same front and rear cover?
3) Same valley cover?
4) Stock LT1 tune should work?
5) When swapping motors, what do I need to keep in mind with the oiling? Are the oil galley's differently?
6) Does the L86 block share the same oil cooler provision as the LT1?
Thanks for any tips!
Alot of L86 specs here: https://www.onallcylinders.com/2018/...am-specs-more/
Ventmaster is offline   Reply With Quote
