09-21-2021, 08:42 AM | #15 |
Instagram: Sangstah
Clean with isopropyl alcohol, sand with high grit sandpaper, spray with adhesion promoter and then satin black, you should be fine.
2019 SS 1LE - "CaSSandra" 2014 SS - "AleSSandra - Sold" 94 Z28 - Sold
Follow the build https://www.camaro6.com/forums/showthread.php?t=612717 |
09-21-2021, 08:52 AM | #16 |
A legend in his own mind
Drives: 2010 2SS/RS M6 Join Date: May 2013
That seems to be my plan minus the heavy sanding, I dont want to lose the texture on the louvers.
2010 2SS/RS "The Mistress"
Color matched OEM GFX / VIS Carbon Fiber Hood (absolute trash quality and customer service ) / Heritage Grille / 5% Windows / 30% Windshield tint with 5% visor strip / Tinted Exterior Lights / Streetfighter LA Spoiler / Morimoto XB LED fogs / LED sidemarkers / Airaid CAI / Hurst Short Throw / TSP LT's / No cats / No resonator / Corsa Xtreme Catback / Trifecta Tune / Factory amp replaced / 2 JL Audio 12's in the trunk / MRR 228 Wheels / BMR Springs / Moog Endlinks / R1 Concepts Rotors & Pads |
09-21-2021, 10:01 AM | #17 |
Drives: 2SS/RS Join Date: Sep 2008
If you are going to paint them, you have to, no option. Paint will not adhere to plastic if it is textured like that. You must sand it down completely and get it all 100% (don't miss any corner or edge) or in a month or two it will peel right off.
09-21-2021, 10:08 AM | #18 |
Even if I use an adhesion promoter? Maybe im way off here but I kind of figured the texture would give the paint something to grab on to lol
09-21-2021, 11:58 AM | #19 |
Many thanks sir!! One of the reasons I bought it was the color.
09-21-2021, 12:01 PM | #20 |
Go getcha some, they look awesome!! I have had more compliments on them at the shows than I ever expected to get, and they have been on quite a while. Don't over think it. lol. Plus it will keep your rear deck area WAY cooler in the sun..
09-21-2021, 12:08 PM | #21 |
DO IT! JOIN THE MOVEMENT lol
09-22-2021, 02:23 AM | #22 |
Completely opposite I'm afraid. The texture actually prevents the paint from sticking. Due to the natural thickness of paint, the paint will only adhere to the ridges of the texture, it won't flow completely down and adhere to the crevices. This creates a weak point in the paint which will eventually crack and peel off away from the crevices.
09-22-2021, 05:29 AM | #23 | |
Drives: 2010 2SS/RS, VR ext/Blk Int Join Date: Jul 2012
I don't think you have to sand completely down. I did a textured diffuser and used adhesion promoter, primer, paint and clear. Came out great and no issues. |
