08-09-2013, 07:47 PM | #1 |
Drives: 2010 IOM 2ss/RS Join Date: Sep 2009
no oil pressure...after turbo install...
So I had my turbo kit installed. finally got it tuned ( don't even ask about that lol - but thank you to diablo for getting it sorted). I took it out for a drive, and the car got HOT! within a min or 2...clearly the radiator needed to purge. took it back to the shop, added coolant , restarted...another drive...car was running fine, temp was good. took it back after a couple min and dropped it back off...
fast forward today. they are moving my car in the shop, start it up and 0 oil pressure. they quickly turn it off. change out the filter, still nothing...now looking at dropping the pan to check the pump...WTF could've caused this??? car is NOT cammed...I am at the end of my rope with this..something that should've been relatively easy has turned into a nightmare. |
08-09-2013, 08:03 PM | #2 | |
Drives: 2010 Cyber Grey Camaro SS (LS3) Join Date: Mar 2010
GPI SS3 Cam / PRC 255 heads / Forged 376ci bottom / Fore level 2 fuel system / D1SC ProCharger on 12lbs / Alky control dual nozzle / 770 whp / 649 wtq tuned by Ryan Stevens at GPI
08-09-2013, 08:07 PM | #3 |
nope and ls3
08-09-2013, 08:32 PM | #4 |
Well a couple things :
1. The relief valve sticking on the factory O/P has been a known issue on LS3 cars. Some guys have had no issues on a modified (and Stock) LS3, and then all of a sudden, boom, zero oil pressure. 2. Now might be a good time to upgrade your O/P to a melling 10296. Considering you have a Turbo, and they are primarily oil cooled, it wouldn't hurt to get a better Oil pump.
08-09-2013, 09:52 PM | #5 |
come find out;)
Drives: stockish 2012 camaro ss Join Date: Oct 2012
In case it is a bad oil pump the melling is a 200 DLL insurance policy and once your in there why not replace a cam keep us updated though
08-10-2013, 01:09 AM | #6 |
how much more work would it be to do the cam? how deep does the rabbit hole go?? lol
08-10-2013, 01:16 AM | #7 |
Quit being a pu$$y
Sounds like you need a new shop.
08-10-2013, 08:40 AM | #8 | |
Keep us updated as they take your Oil pump apart, you might want to take pictures. Check your O-ring as well.
08-11-2013, 08:40 AM | #9 |
Drives: Camaro SS Join Date: Mar 2010
11.90's w/headers, CAI, custom tune, slicks/skinnys, shifter & 100+ Ethyl.
08-15-2013, 07:52 PM | #10 |
so they pulled all the turbo piping, and front off, and dropped the cradle to pull the pan off to check the pick up tube (and pan for any metal). pan was all good, tube checked out fine. so they took out the pump and I put in the melling that everyone recommends (10296 iirc). shazammm...I have pressure. more than I did before...actually almost pegs the gauge at full throttle high rpm.
so my car is back in business and the shop hooked me up right on the deal. anything else I should watch for? |
08-15-2013, 08:08 PM | #11 |
Drives: Camaro 2SS/RS Ice Silver Join Date: Oct 2009
Speed limit.
Keep doing some logging sessions to polish the tune and for anything not in order. |
08-15-2013, 08:15 PM | #12 |
Nice! Glad it worked out.
