Old 05-18-2017, 02:08 PM   #1
G701LE
G701LE's Avatar
Drives: 2010 2SS/RS L99 IBM silver stipes
Why is oil leaking here?
Ok. I have sprung a leak. Oil from the passenger side by the starter. There is something plugged in there. Oil temp gauge? Anyway, I think the leak is coming from there. Well, about 99% sure. There is no where else it could be coming from. And it is isolated to that area.
What is it? And is this a known issue? TIA
2010 Imperial Blue w/ Silver stripes 2SS/RS L99
Mods = Not enough....
G701LE is offline   Reply With Quote
Old 05-18-2017, 02:26 PM   #2
G701LE
G701LE's Avatar
It just starting leaking out of the blue. It was when I was testing tunes and running it REAL hard. Hope I didn't mess anything up. I just need to know the part so I can replace it...
Thinks I will change my name to THREADKILLER
Old 05-18-2017, 02:56 PM   #3
IMadeYouReadThis
IMadeYouReadThis's Avatar
Drives: 02 Camaro SS 6M / 11 GMC Sierra
When you're under the car man snap a picture and post it probably got more help that way bro
IMadeYouReadThis is offline   Reply With Quote
Old 05-18-2017, 03:02 PM   #4
G701LE
G701LE's Avatar
Here goes....
Old 05-18-2017, 03:08 PM   #5
94z28inok
Camaro- Life Member
94z28inok's Avatar
Drives: 15 Camaro 2SS/RS, 19 Tahoe
Send a message via Yahoo to 94z28inok
Looks like an oil level sensor
15 2SS/RS LS3 M6 Summit white
16 200 40mpg Vivid Blue Pearl
19 Tahoe 5.3 Boring Grey
91 Camaro RS 305 TBI 700R4
85 Corvette - TBD
05 Envoy 4.2 4x4
94z28inok is offline   Reply With Quote
Old 05-18-2017, 03:12 PM   #6
94z28inok
Camaro- Life Member
94z28inok's Avatar
Should be around $50 unless you find it cheaper. Just looked up part to confirm, I know the older ones sensor looked identical but wasn't sure if they kept the same one on these motors.
85 Corvette - TBD
05 Envoy 4.2 4x4
Old 05-18-2017, 03:22 PM   #7
G701LE
G701LE's Avatar
I don't have to drop the pan do I?
Old 05-18-2017, 03:29 PM   #8
G701LE
G701LE's Avatar
$44.99 @ AutoZone
Old 05-18-2017, 03:30 PM   #9
94z28inok
Camaro- Life Member
94z28inok's Avatar
No, just drain, and grab it with a big crescent or if you want, take time to find the correct size wrench then ease it out. It'll have an oring gasket on it. Its a few inches long with a float on the end of it, so straight out and don't snag the float ( which shouldnt be a big deal) then clean the area and lightly lube the oring on the new one and back in snug. It is all plastic so don't overdo it.
85 Corvette - TBD
05 Envoy 4.2 4x4
Old 05-18-2017, 03:53 PM   #10
G701LE
G701LE's Avatar
Is it possible not to drain all the oil? Thanks 4 responding.
Old 05-18-2017, 03:55 PM   #11
Cyber10
Cyber10's Avatar
Drives: 2010 Camaro 2SS/RS
Expect a nice mess on the ground if you don't....
491 hp/438 tq
LS3 Conversion | Comp Cam Custom Grind | Mast Heads | Comp Cam Push Rods | LS7 Timing Chain | 180 Thermostat | Ported Intake | Ported TB | SLP UDP | K & N CAI | Custom 3800 Stall Converter | Aluminum 1 Piece Driveshaft | Kooks 1 7/8" LTH | High Flow Cats | ARH 3" Exhaust | ARH Mufflers | Eibach Lowering Springs | BMR Floor Brace Subframe Connectors with Tunnel Brace | BMR Moly Lower Rear Control Arms | Oracle LED Halo Kit
Cyber10 is offline   Reply With Quote
Old 05-18-2017, 04:02 PM   #12
G701LE
G701LE's Avatar
Ok. Sounds like an oil change too. Thanks for the info everyone!
Old 05-18-2017, 04:11 PM   #13
G701LE
G701LE's Avatar
Is this a common problem? It's weird after only 35,000 miles something like this would happen?
Old 05-18-2017, 04:38 PM   #14
kmarshall2121
kmarshall2121's Avatar
Drives: 2012 45th Anniversary Edition
35K on a 2010? youre not driving it enough. things will also go bad when you just let them sit...
kmarshall2121 is offline   Reply With Quote
