06-16-2014, 07:59 PM | #1 |
HARD WORKING PATRIOT
Drives: 2011 CAMARO 2SS RS-AUTO Join Date: Oct 2010
Resolved
Resolved.
Thanks. Last edited by HRD_WRK; 06-22-2014 at 12:56 PM. |
06-19-2014, 05:26 PM | #2 |
Long time avid daily reader -thanks to all for your helpful threads!
Bolt ons, Stock Torq Converter - 11.810 & 116.21 |
06-19-2014, 06:47 PM | #3 |
Drives: cars Join Date: May 2011
B, A is too unbalanced.
06-19-2014, 06:56 PM | #4 |
What effects?
06-19-2014, 07:06 PM | #5 |
Well ZL1 brakes is just a waste of money in that setup and it will be very unbalanced during autocross. Just buy good pads for when you autocross.
06-19-2014, 07:15 PM | #6 |
Thank you for. Your comments.
If you got the ZL1 brakes for free-same response? Please ignore costs for now- Im more interested in performance effects of A and which A vs B is best.
06-19-2014, 07:24 PM | #7 |
You would always be overpowering your front tires and locking them up well before you got max stopping power from your rears. So its possible you may end up stopping slower, not faster unless you ran really unbalanced pads but then you have uneven heat issues. It would increase oversteer and unbalancing the car. Just like everything else brakes need balance to work at their max potential. What wheel and tire sizes will you be using for autocross?
In drag racing it would only add rotational mass with zero braking benefit since they're not needed. So it would make you slower there too unless your plan was to stuff a crazy amount of tire on 15's. But you'd still be turning extra weight for zero reason. |
06-19-2014, 07:35 PM | #8 |
If anything I'd do SS fronts, v6 rears with slicks and skinnies and good pads. Do the ZL1's fit 17 fronts? The master cylinder won't be as unbalanced that way either and you get the lowest weight. My 2 cents at least.
06-19-2014, 08:14 PM | #9 |
Thanks-this is the kind of feed back im looking for.
I have learned from some of your comments, agree with some but not all (drag racing side). I do understand adding the ZL1 front and keeping the back SS would be better than option A-but not the inquiry. I would add to the conversation-staying on topic(leaving Drag out): Is it not true that most of the stopping power is the responsibility of the front brakes? Can the best pads be added to the rear V6 brakes to make them closer to match the SS (and ZL1-since they are the same in back as SS)?
Bolt ons, Stock Torq Converter - 11.810 & 116.21 Last edited by HRD_WRK; 06-19-2014 at 08:42 PM. |
06-19-2014, 08:48 PM | #10 |
I believe there is a consensus that larger rear tires causes additional understeer.
Would less rear speed reduction from option A reduce understeer? Thanks
06-20-2014, 03:51 PM | #11 |
You disagree with unknown portions of my advice for unknowns reasons so you don't want to talk about it anymore.
And your solution would be to use tires to create a car that handles like crap in turns to overcome an unsettled car with bad brake bias in braking zones due to an intentionally poor parts choice? Sometimes someone isn't asking the right questions hence advice is given. |
06-20-2014, 04:16 PM | #12 | |
I am just trying to stay on topic without writing a novel of all my reasoning for the parts Ive choosen for My car's purpose-as directed by several experts. You were also diving into the drag side of things, which I was not inquiring about and I have no desire to argue about that side of things-not why I started the thread. The inquiry is straight forward and the deviation from setup B to A would yield identifiable results. Im just looking for those results, weighing them in the big picture of my car's use. I Thank you for you time and input. I am truly interested in the help
Bolt ons, Stock Torq Converter - 11.810 & 116.21 Last edited by HRD_WRK; 06-20-2014 at 04:45 PM. Reason: help |
06-20-2014, 04:34 PM | #13 |
Negative Camber Junkie
Drives: 2010 1SS LS3/6MN ABM 1 of 23 Join Date: May 2009
Tim,
The stock SS front brakes are quite capable and if you are not doing road course then you really do not need the ZL1 calipers. Don't believe me and Synner.... Check out what JP said to a road course guy about the SS calipers... http://www.camaro5.com/forums/showthread.php?t=361444 Just choose the right pads, NOT OEM, and you can do quite well in AutoX. BTW, good pads squeal, dust, etc. No way around it. T.
"Horsepower is something that looks great in a Magazine article, but suspension is what actually gets you around the track fast.." Jack Olsen
The drag strip is like sniffing glue, it's cheap, it's a decent buzz, it doesn't last long and they are all the same. Road racing is like China White Heroin, the buzz is stronger, the high lasts for hours, it's extremely addictive and they are all different. I can't wait for my next Track fix. DA HAWKS OWN DA CUP!!!!! |
06-20-2014, 04:42 PM | #14 | |
