Roto-Fab
Old 02-24-2022, 12:52 PM   #1
Archer428
Drives: Camaro
Camaro headlights question and options to fix low output
2010 Camero SS with the RS package
HID headlights
I have been reading some post on this subject and really just wanted confirmation on the process to correct the low output from the headlights.
So far from what I have been reading
Option 1 is to replace the HID blubs and hope this makes a difference.
For the ones that have had success with just bulb replacement what bulb did you use and where did you buy them, what was the cost for them?
Option 2 If changing the bulbs did not improve, check the ballast to see if they are working correctly
Option 3 Install Daytime running light modification for temporary help.
other than morimoto, what are other options.
Option 4 There was a post of using DS1 LED bulbs by bullvision 6000k.
How has this worked for the ones that have tried them?
Option 5 when all else fails spend the money and buy either aftermarket TYC headlights
or OEM headlights
Are there any other aftermarket options other than TYC
Archer428 is offline   Reply With Quote
Old 02-26-2022, 06:37 PM   #2
thef4ng
thef4ng's Avatar
Drives: 2012 Camaro SS A6 SIM
Honestly I I tore apart the headlight and needed up installing some led projectors from the retrofit source. They’re bright as hell and have been working flawless for over 2 years. Can provide pics if you want.
thef4ng is offline   Reply With Quote
Old 02-26-2022, 09:46 PM   #3
Archer428
Drives: Camaro
Pictures
Yes please
Also can you provide a link and part numbers that you used to make this work
Old 02-27-2022, 04:29 PM   #4
thef4ng
thef4ng's Avatar
I used the Mled 2.0 from the retrofit source. I also replaced the halos with color changing ones. It’s not an easy swap. The hardest thing is mounting the projector to the stock bracket. It’s doable. But if you cut too much your gonna need a new bracket. Because there barely any room for error. Wiring the projector to the stock harness makes it work like factory.
Old 03-10-2022, 02:55 PM   #5
Lacpac
Lacpac's Avatar
Drives: 2012 Crystal Red Tintcoat RS
I'm glad the retrofit worked for you. Looks super complicated. I bought the Bullvision LED DS1 but havent got it out of storage to try on the road yet. I've been running 8000 lumen per pair LED in the DRL's but they blind people since they are not focused. Just switched to 4000 lumen per pair. I see at Aliexpress.com they sell fouced DRL that look like that RS headlights with halo's for about $135 a pair. Might be the next step if the change I made over the Winter doesn't please.
Lacpac is offline   Reply With Quote
Old 12-27-2022, 12:47 AM   #6
Tommi
Tommi's Avatar
Drives: 2010 Camaro SS manual
I just replaced the projectors in my camaro. It was quite easy and straightforward job, besides opening the clear headlamp cover / lens. That requires heating the unit in a oven to soften the factory glue. But still very doable in carage conditions. And the result is very good lights.
I used kit from retrofit labs, toughest part is that the kit is made for Ford mondeo MK4... they used the same projector as camaro so the kit works. No cutting and fitting required, just bolt on.
If you want more info, just ask.
And if you want to tell me I should have just bought new lamps, thanks for the info but these work better and also over 1000$ cheaper than new lamps shipped to Finland.
Tommi is offline   Reply With Quote
Old 12-27-2022, 08:24 AM   #7
camguynj
camguynj's Avatar
Drives: '13 SS/RS LS3 BRM Cammed NPP
How long did you have them in the oven and at what temp?
camguynj is offline   Reply With Quote
Old 12-27-2022, 09:29 AM   #8
KenKat
KenKat's Avatar
Drives: 2014 2LT RS Summit White
There are a lot of knockoffs out there unfortunately. I replaced my stock HID bulbs (mine are D3S since it’s a 2014) with what were supposedly Sylvania OSRAMs but based on the pricing ($50 for the pair), they were probably fakes. They were ok brightness wise but only last 2 years and I don’t drive all that much at night.
I replaced those with ones from Diode Dynamics as they are well regarded here and I have been happy with the LED fog lights I installed from them in place of the weak halogen bulbs that were OEM. It looks like they have the D1S available in several color temperatures (I went with 5000k).
KenKat is offline   Reply With Quote
Old 12-27-2022, 11:32 AM   #9
Tommi
Tommi's Avatar
This is copy paste from retrofitlab.com instructions, I used method 2.
https://retrofitlab.com/en-fi/apps/h...ght-to-open-it
"At what temperature do I heat my headlight to open it?
In general, 2 methods are used, with both methods, be careful and patient.
Method 1 is using a regular oven. Preheat the oven at 200 degrees Celsius. When ready, switch off the oven and place the headlight inside. Make sure that the headlight is not touching any metal of the oven by placing a cloth over the grid, for example. Leave the headlight in the oven for 10-15 minutes before opening it. If the headlight kit is not yet soft enough, put the headlight in the oven for a bit more time.
Method 2 is suitable for larger headlights that do not fit in a regular oven, or if your lovely wife absolutely does not allow car parts to be baked in her kitchen. A large cardboard box is used where hot air is blown through a heatgun. Make sure that the hot air of the heatgun does not blow directly to the headlight, place the headlight on small elevations so that the air can circulate properly through the box. We use a setting of 300 Degrees Celsius for 12-18 minutes / 1st lowest setting, depending on the size of the headlight."
My cardboardbox oven from summitracing!
Today I got to test the lights in snowy and dark roads for 60 miles and the lights made it much safer because finally i was able to see.
Old 12-27-2022, 12:03 PM   #10
camguynj
camguynj's Avatar
Thanks for that info
Old 12-27-2023, 04:55 PM   #11
Tuex
Tuex's Avatar
Drives: 2011 Camaro 2SS RS LS3
Made the same conversion and the result is great, see:
https://www.camaro5.com/forums/album.php?albumid=22837
Thx to https://www.camaro5.com/forums/member.php?u=175162
Tuex is offline   Reply With Quote
Old 12-27-2023, 06:17 PM   #12
AlisoBob
Drives: Camaro 2SS Gen 5
SUCH...... a awesome photo.
AlisoBob is offline   Reply With Quote
Old 12-28-2023, 09:39 PM   #13
NZZL1
NZZL1's Avatar
Drives: 2013 BRM ZL1 Camaro M6
https://www.camaro5.com/forums/showthread.php?t=616186
NZZL1 is offline   Reply With Quote
