Old 02-05-2020, 04:39 PM   #15
Whitespeed
Drives: 2018 1SS 1LE & 1973 Datsun 240Z
Originally Posted by Trackjunkie2020_1LE View Post
Anyone running the ZL1 addons plate holder with an additional front license plate cover? Just wanted to know if I'll be needing longer screws due to the additional thicknesses of the cover. I'm assuming the ones provided won't work with a cover.
Can anyone tell me the specs of the longer screws?
The screws provided with the ZL1 Addons plate were a very small diameter, and even with washers, were almost too small for the holes in Ontario plates. I ditched those right away. I installed M6 (or maybe it was M5?) threaded inserts (https://www.princessauto.com/en/deta...it/A-p8514234e) in the ZL1A plate so I wouldn't have to fiddle around with trying to hold nuts in place from the rear while getting screws started from the front. I put a rubber vaccum cap on the threaded insert closest to the bumper so that if the bracket bent, the insert wouldn't leave a mark on the bumper. I then just figured out how long of a screw I would need. I don't recall off hand what I ended up using though. I can check.
I also replaced the included socket head allen bolt, used to attach the ZL1A plate to the post that goes in the tow hook hole, with a hex head bolt. This way I can use a wrench to get the plate on and off easily by reaching in behind with a ratcheting box wrench. Much easier than undoing all four bolts on the license plate to get an allen key through the hole in theZL1A plate to access the allen bolt.
Whitespeed is offline   Reply With Quote
Old 02-05-2020, 04:41 PM   #16
Eldi Z
Drives: 17' 1SS 1LE GBA-Black
Originally Posted by Eel125 View Post
...NY has other issues to worry about with all the criminals they let out on bail reform to worry about your front plate...they dont enforce turnstile jumping so why would they enforce that
Old 02-05-2020, 04:44 PM   #17
Eldi Z
Originally Posted by Xile View Post
California requires it too, but I've never put them on any of my cars and never had a problem. I guess if the cops are really bored or have nothing better to do you could get a fixit ticket. But nobody I know uses a front plate and has never had an issue. I just like the cleaner look personally.
How much is a Fixitticket?
Where I am stationed its a $150 fine.
Old 02-05-2020, 05:05 PM   #18
Xile
Drives: 2019 Camaro SS 1LE
oof thats crazy. Here you fix it, and pay a $25 to the court to dismiss it after chp confirms its fixed.
Xile is offline   Reply With Quote
Old 02-05-2020, 09:12 PM   #19
50MileSmile
50MileSmile's Avatar
Drives: 2023 2SS, 2018 1SS 1LE, 1993 Z/28
Over the years, I’ve tried just about every front license plate holder on the market - and built several of my own. I spent many hours trying to design one for my ‘18 SS 1LE, and none of my ideas worked as well as the Sto N Sho. It’s solid, never rattles, attaches to the Camaro’s OEM mounting points and is completely hidden when the plate is off. Since I live in a state where running without a front plate is a moving violation, the Sto N Sho was the best solution.
https://bigmikesperformanceparts.com...e-pack-sns89c/
50MileSmile is offline   Reply With Quote
Old 02-12-2020, 04:56 PM   #20
eimarshall
eimarshall's Avatar
Drives: 2018 SS 1LE Hyperblue
I got pulled over for not having it displayed in WA. I had it in the front window wedged in the corner on the passenger side. They didn't like that and just gave me a warning. I run the ZL1addons tow hook bracket now and it takes a minute to swap it out for track/autoX.
eimarshall is offline   Reply With Quote
Old 02-12-2020, 05:18 PM   #21
Eldi Z
25$ is absolutely fair - I could live with taking the risk and getting one once in a while
Old 02-12-2020, 05:35 PM   #22
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
its only $25-50 in cali still but if they pull you over for that they normally try to get you for exhaust or tint or other dumb shit so i just keep one on my car and pull it off and put on towhook when i go to the track
kropscamaro16 is online now   Reply With Quote
Old 02-12-2020, 05:38 PM   #23
kropscamaro16
adam carolla said it best...
what could be more dangerous. This is all over LA but if you have a car with no front license plate you need to be stopped
Old 02-12-2020, 07:23 PM   #24
crab
crab's Avatar
Drives: 2019 1LE
Solved my problem today...
"That my friend.. is the sweet succulent sound of the car preparing to ignite the wonderfully tasty nectar your V8 needs to send the screaming bald eagles furiously from the 4 pipes out of the rear of your vehicle"
crab is offline   Reply With Quote
Old 02-12-2020, 08:15 PM   #25
+1 for the Sto'n'Sho, it has different versions for standard and 1LE splitter equipped cars, plate removal is easy (some say too easy even...), and it seems to be pretty good quality, no rusting or bending or any other issue at all after almost 2 years.
Old 02-12-2020, 09:39 PM   #26
Vtor_ZL1
Who Needs to KNOW?
Vtor_ZL1's Avatar
Drives: 18 ZLE
Depending how you drive, may be worth keeping front plate, fewer things to be harassed about - fewer reason to pull you over as well. Not worth the headache either way.
Sto-n-show user. makes 650hp front plate friendly.
ing for grip.
http://www.motorsportsne.com/
Old 02-13-2020, 05:00 PM   #27
Eldi Z
Words of wisdom
Old 02-20-2020, 03:26 PM   #28
NYblack1le
Took 3 tickets for me to finally put the front plate on my 1LE. It’s a state troopers favorite ticket to write.
NYblack1le is offline   Reply With Quote
