12-03-2021, 11:41 AM | #1 |
Drives: 2018 ZL1 Join Date: Jun 2020
Lower Pulley Boost Increase Comparison
I have a 2018 ZL1 with a green filter and TM ported throttle body Stock Tune
I'm considering a balancer and pulley swap soon. I'm taking baby steps first and I'm looking at three pulley sizes: 8.6 (7.5%) 9.06 (12%) 9.10 (13.75%) Keeping the stock upper 2.5 pulley, does anyone have any idea what the boost increase would be for each or any of the above sizes?? TIA |
12-03-2021, 11:51 AM | #2 |
Drives: 2021 Red Hot ZL1 Join Date: Sep 2020
12-03-2021, 01:00 PM | #3 |
Thanks, that helps!
Curious if anyone out there obtained those increases after installation? And if I read correctly I need to upgrade the crank seal to an LS seal? |
12-03-2021, 01:56 PM | #4 |
Oh Oh it's Friday Night!
Drives: 2018 ZL1 1LE Nightfall Gray Join Date: Jan 2018
Really recommend headers if you are adding a lower pulley. You will need a tune anyway and pushing more air in will require a more efficient exhaust system on the back side.
Four that wanna own me Two that wanna stone me One says she's a friend of mine... |
12-03-2021, 02:30 PM | #5 |
Drives: HBM ZLE Join Date: Aug 2017
Seems to be recommended but I didn't replace mine when I did the balancer swap and have had no issues so far after 1500 mules
12-03-2021, 02:32 PM | #6 |
Drives: 2019 Chevy Camaro ZL1 M6 Join Date: Jul 2019
Pulleys would be my last mods. I’d get an upgraded heat exchanger, coolant reservoir and ceramic coated headers first. I’d also add flex fuel if it’s available in your area. You will be adding heat with pulleys.
Kong Stage X Port, NW103, LPE HPFP, XDI +30 Injectors, ARH Headers, Flex Fuel, JMS Booster, AWE Touring, Elite E2-X CC. Stock heads, stock cam, stock pulleys: Tuned by KingLT1. 740whp Uncorrected on e50
12-03-2021, 03:02 PM | #7 |
Wish we did have E85 here local, but nearest station is 25 miles away.
I know the headers would help and possibly drop the boost a little, but was just looking for mild upgrade .. If the 8.6 would truly provide a 2lb increase that would satisfy me for now...(maybe). Its a daily driver and use 93, just didnt want to go to much further than that and risk knocking and too much additional heat. Of course it'll be tuned too. May upgrade the heat exchangers too. |
12-03-2021, 07:41 PM | #8 | |
Drives: 2021 Camaro ZL1 A10 Join Date: Nov 2018
If it's only 0.7 psi, it won't add that much heat (about 14-15 deg F over stock compressed temperature).
2021 Camaro ZL1 A10
2022 GR Supra 3.0 Past: 2018 Mustang GT Premium w/ PP1, MR, and A10 2007 MazdaSpeed3 1995 Pontiac Trans Am 1987 Camaro Z28 |
12-03-2021, 08:08 PM | #9 | |
Drives: 2019 ZL1 Join Date: Mar 2019
You would need a 9.17" to get close to 2PSI. The 8.6 isnt going to provide much. Also, your engine is a big air pump. If your moving more air in, you must move more air out or its simply not efficient.
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90 |
Thread Tools | |
