12-02-2021, 04:19 AM | #1 |
Drives: 2015 Camaro SS Join Date: Mar 2021
Power stop brake rotors
Going to replace my rotors and not sure what brand to go with.
Are power stop rotors any good? Looking for something similar to oem but possibly cross drilled and slotted. Also will any rotor work with the brembo calipers? |
12-02-2021, 06:25 AM | #2 |
Drives: 2013 L99 Join Date: Jan 2019
I got original Bembro rotors made in Italy on Amazon for $75 ea. Pretty hard to beat that
12-02-2021, 07:41 AM | #3 |
Jedi Master
Drives: Boeing 757/767+2010 IBM 2SS Join Date: Aug 2008
Sounds like a company played on the name “BREMBO” to increase their marketing a bit. Hope they work out for you.
12-02-2021, 08:09 AM | #4 |
I just replaced mine with OEM...
12-02-2021, 02:23 PM | #5 |
Sporting Foole
Drives: 2010 Camaro SS Join Date: Sep 2019
I'm a big Powerstop fan, went with the vented rotors and carbon ceramic pads.
It will sling the bugs off the front bumper late barking hard into a turn! |
12-02-2021, 02:48 PM | #6 |
Drives: 2011 Camaro RS/2SS M6 Join Date: May 2019
I've had Powerstop on the car for 2 years now with no issues. As for performance, I can't notice a huge difference. With that being said, brake dust is almost non existent compared to OEM and they still look great after 2 years and hard driving. Bedding process is important with the extremes, but well worth the $$.
Heads/Cam/Intake with supporting mods - Built by Spartan LSX in Auburn, GA
12-02-2021, 03:23 PM | #7 |
Drives: ABM #93 Join Date: Oct 2018
I was going to try the power stops as I had a pretty bad shake at speed when using moderate pedal input. Had it since the day I got it. I could get them to behave mostly by mashing the pedal a few times doing panic stops and getting the pad buildup cleaned up from rotors but it always came back. I was about to pull the rotors and replace them. I pulled them and they were straight as an arrow and had minimal wear. I chucked them into the sand blast cabinet and blasted the pad surfaces on both fronts. Re bedded the pads and for a few thousand miles I haven’t had any issues at all. That’s my cool story for the day
ABM #2399 2SS/RS:SOLD
ABM #93 2SS/RS Black Rally stripes, Titanium Interior 4,000 miles: GM GFX side skirts and diffuser waiting on paint, GM dovetail, GM heritage, RPI ZL1 style splitter. ‘87 IROC-Z Iroc blue. all original unmolested with 50K miles. |
12-02-2021, 05:38 PM | #8 |
Drives: Two 1984 Z28 / 2014 2SS/RS AGM L99 Join Date: Feb 2021
Another vote for the Powerstop kit . I put them on within a month of buying the car last Feb. and have had zero issues !
2014 2SS/RS AGM L99
CAI Intake ELITE Catch Can POWERSTOP Brakes (5/31/21) |
12-02-2021, 05:40 PM | #9 |
Thanks guys I was looking into this set here but wasn’t sure.
12-02-2021, 06:58 PM | #10 |
Drives: 2012 Camaro SS Join Date: Dec 2019
Those are the ones I was looking into too
They seem to be really good for the price.
2012 Camaro 2SS/RS - CSP Custom Cam 232/240 .615/.615 113 +3, Texas speed CNC heads, FTI billet triple disc converter, K&N cai, Katech ported TB, GPI Ported/rod modded manifold, Texas speed 1 7/8 headers, HFC, Flowmaster 2 chambers with x pipe, Mishimoto CC, MSD wires, Roto fab washer relocation, tru cool 40k trans cooler, apex scoop, Pedders extreme coil overs and much more!!
12-02-2021, 08:18 PM | #11 |
Drives: 2010 Camaro 2ss/rs, 2008 Avalanche Join Date: Jan 2019
Got my Powerstop set up from Rock Auto ,well worth it!
2010 Rally Yellow 2ss/rs , M6 ,416ci , K1 rods & crank,weisco -3.0cc dome pistons,.040 head gasket, 11.5 compression,1 3/4" LT ,3" pipes w/x-pipe no cats, Cam Motion cam 239/247 113+3 .621"/604" lift , BTR .660 Platinum dual springs w/Titanium retainers, CAI . Stock ls3 heads,intake,injectors & TB. 515rwhp/500rwtq.
12-03-2021, 12:43 AM | #12 | |
12-03-2021, 06:26 AM | #13 |
Drives: 2013 Camaro 2SS AGM Join Date: Apr 2020
I have no issues with mine, very smooth. As mentioned already bed the pads in correctly. I also replaced all my caliper bolts as they are torque to yield. There are many threads here on replacing the bolts or not. I changed them for peace of mind.
12-03-2021, 07:39 AM | #14 |
I run mine pretty hard when we go run the nascar ovals. The shake was there in daily driving as well but no where near as bad as on the track. I could get them decent enough for daily driving but it’s a bit unnerving when they are shaking at over 100 mph in a 20*+ banked corners.
Tags |
brakes & rotors |
