11-30-2021, 07:32 AM | #1 |
Limitless Imagination
Drives: 2018 ZL1 & 2022 Hayabusa Join Date: Dec 2016
Odd Front PS4S Tire Wear
Anyone else's PS4S do this on the fronts? Tires were purchased new locally, they're about 6 weeks old and have a couple thousand miles on them.
The rear tires (315/30) don't do this. To me it looks like low pressure, but I've run 32-33 in them since day 1. This weekend I bumped it up to 35, no difference. Any ideas as to a fix?
2018 Camaro ZL1 - Black
- OEM Options: A10, Exposed Carbon, PVR, Nav, No Sunroof - Lightly Tinted GM Dark Tails, DD Side Markers, Morimoto 5000k, 100% LED - RotoFab Dry, Forgestar CF5V (ZLE Spec), Eibach Pro, AeroForce Interceptor, GT4 Tow Hook - Carbon Fiber (Satin): Radio, Shifter, Steering Wheel Controls, Shifter Top, AC Vents, Side Mirrors & Shark Fin 2022 Suzuki Hayabusa - Brilliant White Pearl & Shocker Yellow Wheels - +4 Arm, 240 OEM Wheel, Brock's CT (Ti) Exhaust, 1.25" drop, etc... |
11-30-2021, 07:57 AM | #2 |
Who Needs to KNOW?
Looks like driven hard and understeer ? ie scrubbed sidewall?
Checking pressure via DIC or pressure gauge ?
ing for grip.
11-30-2021, 08:05 AM | #3 | |
Checking pressure via both, they're all spot on or within 1psi of DIC. Never had a low tire alarm or anything, even with the drop in temp recently. It's just weird, I almost want to say something is wrong with the tires or maybe guess could be the car. BTW car is lowered on eibach and had an alignment at the same time the PS4S were mounted. Nothing looks out of place or odd.
11-30-2021, 08:21 AM | #4 | |
Drives: ZL1 1LE on order Join Date: Nov 2021
11-30-2021, 08:38 AM | #5 | |
I'm kind of at a loss as to why these tires are doing this.
11-30-2021, 09:07 AM | #6 | |
Drives: 2019 Chevrolet Camaro 2SS Join Date: Jul 2019
11-30-2021, 09:13 AM | #7 | |
I did pull the front wheels off last night, treadwear seems even visually at the moment.
11-30-2021, 09:38 AM | #8 | |
Drives: 2020 Camaro ZL1 Join Date: Oct 2020
2020 ZL1 A10 Shadow Gray Metallic
Magnuson Magnum DI TVS2650R| Mamo Throttle Body V2| RotoFab Intake| AWE Touring Catback Exhaust| TCM Tune| Tune| Eibach Pro| BMR Rear Cradle Lockout| PPF| Ceramic| BCForged HCS21 |
11-30-2021, 10:07 AM | #9 |
Drives: 2018 ZL-1 Join Date: Jan 2018
Did you replace the bolts and nuts when you did the alignment? I believe you have to replace 8 bolts and nuts at that time.
I used to have to have my car aligned every 2000 miles because I ignored the requirement for new bolts. It didn't make sense to me until I saw a Youtube video about Torque to Yield bolts, and why they need replacing. When I had the dealer align it with the new fasteners, it has stayed aligned for 6000 miles so far. |
11-30-2021, 11:09 AM | #10 |
Drives: 2019 ZL1 1LE Join Date: Feb 2017
It looks like you sometimes have the wheel hard to the left and you go either through a road side rain gutter or up a steep parking lot entrance ramp?
What I'd do is clean the tire real well, let it dry, then get some chalk and draw a heavy line on the shoulder of the tire going from the top of the tread down to where the writing is on the tire. Drive it around some like you normally do and see how far down that line has gotten scrubbed away.
Old: 2017 SS 1LE
Old: 2017 ZL1 Current: 2019 ZL1 1LE |
11-30-2021, 11:42 AM | #11 | ||
That's a great idea, I have some chalk to give this a shot. Just to make sure it's actually scrubbing itself and not some oddball thing going on. Probably will do both tires, just for kicks.
11-30-2021, 10:03 PM | #12 |
Marked both fronts (no scrubbing clean) before going to pick up my daughter from daycare so put 100 miles, just normal driving, no issue (see pics).
Will drive more aggressive tomorrow, especially around corners and see the outcome. If no different, I'll drop pressure back down to 32 again and try again.
12-08-2021, 10:11 AM | #13 |
After a week or so of driving with the chalk on the tires, the chalk was untouched. Dropping them from 35-36 back down to 32psi and see what happens.
https://www.camaro6.com/forums/showthread.php?t=584431 Happen to randomly open this thread and noticed his PS4S front tires have similar sidewall wear. Almost kind of wonder if they were like this from the start and nothing my Z did to them.
