09-09-2021, 08:54 PM | #1 |
Drives: 2014 2SS/RS 6SP Ashen Grey Join Date: Aug 2021
Ashen Gray 14 2 SS ZL1 Side skirts Paint body color or leave black? OEM or aftermark
Hi, Ashen Gray 14 2 SS/RS thinking of buying Factory ZL1 Side skirts, I am assuming they will come Black plastic color, should I leave them or paint them body color? I am planning on adding Matte or Satin black rims as well.
I am thinking Black would look nice but not sure. Also OEM or Aftermarket? Thanks
GM 3.91/TrueTrac OEM ZL1 Rims, Brakes & Side Skirts.ACST4 Splitter/Deflectors NPP M2W,GM Short Throw,Remote Clutch reservoir
GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, Moroso Catch Can GC Aluminum DS Stainless Works Ceramic LTH/HiFlo Cats SCT X4 Dynosteve, Hotckis 1" Springs & Chassis Max Brace BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings Pedders Radius Rod Inserts Strut tower brace Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights AeroForce Dual gauge/Autometer pillar mount. |
09-16-2021, 07:48 AM | #2 |
I ordered OEM ZL1 Skirts, My buddies who owns a body shop is going to paint them, Do you guys know if they come with new clips?
09-16-2021, 11:09 AM | #3 |
Drives: Camaro 1LE Join Date: May 2018
Mine did
09-16-2021, 01:52 PM | #4 | |
Drives: '12 Camaro 2SS/RS Vert Join Date: Oct 2020
2012 Camaro SS Convertible: 2SS, LS3, M6, Triple Black. Mods: Solo Axleback, 1LE FE6 rear swaybar, CAGS delete, Vararam CAI, Heritage grill, Hotchkis springs, '15 FE4 struts/shocks, ZL1 side rockers, Velgen Classic5 wheels, Pedders radius rod bushings, ARH LTHs, gutted HFCs,...
09-16-2021, 09:50 PM | #5 |
I guess from what I am reading is that the top plastic part needs to be painted or the sun will gray them out.
09-26-2021, 07:15 AM | #6 |
So i am painting them Body Color and leaving the line and below Black, Do i want to paint them a satin/Flat black or leave them plastic to match the grills and bumper? Does the textured plastic hold up? The car is not going to be baking in the sun all day but will be outside from time to time in the elements.
09-27-2021, 08:10 PM | #7 |
If you do leave the bottom portion the matte color it is and paint the top, just make sure you use a quality cleaner/protectant on the bottom half so it doesn't gray out. I have a friend who has a 2013 ZL1 from brand new and they look JUST like brand new!! Key is to keep them clean and treated.. GL.
09-28-2021, 08:39 AM | #8 |
Drives: 2010 Camaro 2SSRS M6 Join Date: Jan 2019
Not ashen gray but it is CGM. Top is painted and the bottom is not.
ECS supercharger, custom ground cam, ported throttle body, long tube headers, aeromotive fuel pump, fic injectors, ATI super damper, Corsa Extreme exhaust, elite engineering catch can and many other things.
09-28-2021, 08:59 AM | #9 |
Your Camaro looks just amazing sir!! Gets me every time I see it.
09-28-2021, 07:55 PM | #10 |
Thanks. Same to you.
09-28-2021, 08:56 PM | #11 |
Both of you guys have great looking cars, What color is CGM? I like the Noses you guys have with the opening.
09-29-2021, 09:21 AM | #12 |
CGM is Cyber Grey Metallic, and if you are talking about our grilles, it is the Heritage grille. Thanks for the compliments too..
09-29-2021, 07:57 PM | #13 |
Here is a better pic of the front. As 1JEWLDSSRS said it’s the heritage grill. Thanks for the compliment
09-30-2021, 06:31 AM | #14 |
Camaro2SS, I am talking about the opening between the hood cowl and the grill. What splitter do you have?
