03-07-2020, 08:18 AM | #15 | |
aka BeastZL1
Drives: 2019 Camaro ZL1 1LE, 2004 Cobra Join Date: Dec 2017
@EDFHOBBIES please post some data when you have it! Thanks.
10-25-2021, 08:57 AM | #16 |
Petro-sexual
Any updates on this?
10-25-2021, 12:12 PM | #17 |
Dyno Show Queen LOL
The exchanger has been great. But I also have a 5 gallon tank in the trunk.
100 degree temps cruising I see.. IAT 1 100 IAT 2 108 TO 110 IAT 3 126 If I go through 3rd and 4th on highway I see. IAT 1 100 IAT 2 108 but falls to 100 or 99 IAT 3 126 falls at 1st then rises to 136 then a 1/2 mile later at 70 it back to 126. At resting the AC fans aren't strong enough to keeps temp down. I would suggest mount 2 or 1 big fan for long idle periods. However once moving at 60 or 70 temps fall back to cruising temps in about 8 to 10 mins they start to fall immediately but the last 3 or 4 degrees take the 8 to 10 mind but after 3 or 4 min of driving they are almost normal.
10-25-2021, 01:13 PM | #18 | |
Petro-sexual
Thanks again for sharing.
10-25-2021, 02:04 PM | #19 |
Dyno Show Queen LOL
The ac has no change in temp but it will lower the iat 2 a bit sitting vs no circulation of cooling fans
10-25-2021, 02:07 PM | #20 |
Petro-sexual
Any data on the engine coolant?
10-25-2021, 02:59 PM | #21 |
Dyno Show Queen LOL
Next time out I'll monitor that.
10-26-2021, 07:43 AM | #22 |
Petro-sexual
Cool. For the price of these, even though it might not be that effective for my combination, it wouldn't be a huge loss if it didn't work out that well. If coolant temps don't change much (nor AC operation), I'd probably jump on this.
10-26-2021, 08:36 AM | #23 | |
Dyno Show Queen LOL
My 5th gen was twin turbo it had the upgraded AGP at least 4 inches thick I ran into higher coolant temps and oil coolant sitting still I had to shut AC off in traffic once I turned the AC off the fans brought it back to normal temps. Even with the higher temps I didn't notice AC not cooling
10-26-2021, 12:52 PM | #24 | |
Drives: 2021 Red Hot ZL1 Join Date: Sep 2020
10-26-2021, 09:26 PM | #25 | |
Drives: 18 ZL1 Convertible Join Date: Jun 2019
10-27-2021, 04:28 AM | #26 |
Dyno Show Queen LOL
Rhodes Racing from jegs 5 gallon
Stewart emp pump Bought the 2 parts together and fittings used 50 bucks off coupon. Just picked up the weaponx for wife's car found it for 300 shipped. It's 6 gallon I believe and fits under carpet I had a 3 gallon built for hers and fits between the modules with out having to relocate them however it's tad to tall and somehow her lid keeps breaking from setting stuff in trunk so I'm gonna replace hers. I didn't need the trunk space so mine comes up through the carpet. I still have room for golf clubs w seat down. https://www.camaro6.com/forums/showthread.php?t=586298
10-27-2021, 11:51 AM | #27 |
Drives: 2019 ZL1 1LE Join Date: Feb 2017
If you're trying to control heat, have you thought about putting in a better oil cooler? I'm looking at this option, partially because of the heat here in Phoenix. Oil temps are getting up into the danger zone on a regular basis.
https://www.crracing.com/product/che...-ss-oil-cooler
Old: 2017 SS 1LE
Old: 2017 ZL1 Current: 2019 ZL1 1LE |
10-27-2021, 12:29 PM | #28 | |
Dyno Show Queen LOL
