Roto-Fab
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Camaro Issues / Problems | Warranty Discussions | TSB and Recalls
Old 01-14-2016, 03:46 AM   #1
Adrian09
Drives: 2013 Camaro 2SS/1LE
First gear require gas at all times?
I've been having this problem since I got the car and it can be easily ignored but I need to know if something is actually wrong.
After shifting into first gear, the moment I take my foot off the gas my car starts to want to stall. It feels like it's desperately needing more gas so I either give it gas or press the clutch in. I usually just avoid this by going to second gear but it's not always convenient to go into second. I also have the same problem in second but it's not as bad. Do I have a problem or are camaros just too heavy and need a constant supply of gas in first gear?
Adrian09 is offline   Reply With Quote
Old 01-14-2016, 06:31 AM   #2
Gonzo SS
Gonzo SS's Avatar
Drives: 2012 IBM 2SS/RS LS3/M6
I do not have that problem in my 2012 LS3. On level ground I can slowly let the clutch out and roll in 1st without giving it any gas.
Sent from my LG-H811 using Tapatalk
Stainless Power LT Headers, K&N Typhoon CAI, VMAX Ported Throttle Body, Jannetty Tune, Phastek Scoop & Washer Bottle Relocator, VTC
Resonator Delete w/Flowmaster Super 10's, BMR Lowering Springs, Koni Orange Struts, Factory Hurst Short Throw Shifter, Skip Shift Eliminator, DRL & Halo Harness, Window Valet
Scosche Kit w/Pioneer AVH-4100NEX, Lloyds Custom Mats, Blue LED Footwell Lighting
Gonzo SS is offline   Reply With Quote
Old 01-14-2016, 07:16 AM   #3
Olddudesrule
Resident nomad
Olddudesrule's Avatar
Drives: 2014 Summit White 1SS/1LE
Is the car bucking if you let out the clutch and don't give it gas? I've had a few manuals that need a little pedal or they will buck and stall. Mainly was due to a low idle speed, not enough to overcome the drop in RPM when the clutch engaged, but since your's is also doing it sometimes in 2nd, I'm wondering if your clutch is slipping? Any known clutch issues prior to this?
Sold:
2007 Z06
2002 Viper GTS/ACR
2003 Z06
1965 FFR Cobra
2012 Nissan 370Z
ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing.
Olddudesrule is offline   Reply With Quote
Old 01-14-2016, 08:32 AM   #4
AGM 1LE
AGM 1LE's Avatar
Drives: 14 SS/ 1LE
what RPM is it doing that at?
AGM 1LE is offline   Reply With Quote
Old 01-14-2016, 01:22 PM   #5
xc_SS/RS
Drives: 2010 Camaro SS/RS
Well when you take your foot off the gas the engine is braking and slowing you down. In higher gears this isn't as noticeable since first gear is geared to be very short (more torque to get moving). So in first you usually will need to apply gas unless you are on flat ground and can roll along in first just using the engines idle speed.
So yes gas in first is necessary lol
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53
xc_SS/RS is offline   Reply With Quote
Old 01-14-2016, 01:28 PM   #6
blakjak55
drinks virgil's
blakjak55's Avatar
Drives: 2010 2SS M6
With 3.45's, you're almost always going to need gas. With the 3.91's, it'll still stall if you let the clutch out too quickly but it's quite a bit better.
2010 2SS/RS M6 - CAI Intake - Borla Stinger - VTC - 3.91's
Eibach Sways - LG ZR28's - BMR Springs - 285/35 Squared
blakjak55 is offline   Reply With Quote
Old 01-14-2016, 01:42 PM   #7
crimsongtp
crimsongtp's Avatar
Drives: 2014 AGM SS/RS 1LE
This. I cant speak for the 3.45s but with 3.91 there are days I accidentally let it out too quickly (giggity) and it bogs a little. a bit touchy.
crimsongtp is offline   Reply With Quote
Old 01-15-2016, 04:03 PM   #8
Adrian09
For some reason I couldn't find this thread yesterday lol
If I'm in first and get up to around 10-15 mph and let go of the gas it will start to jerk. Even with a slight decline. It does it right below 2000 rpms. If it's closer to 1000 it does it more but at that point it's obvious that it's natural. I was just wondering because I got it used and it came with a borla exhaust and I was wondering if I need a tune. I have a 1LE btw so I have the 3.91 ratio.
Old 01-15-2016, 07:09 PM   #9
1Coopgt
1Coopgt's Avatar
Drives: All Black 2012 1LS
It's normal .
Mods, K&N CAI ,VTC , GM Perf Axleback Exhaust, Elite Eng CC and CSS, GM Strut Tower Brace,Carbon Fiber Anvil Spoiler,ASC T5 Splitter,Gen5diy Foglight kit.
1Coopgt is offline   Reply With Quote
Old 01-15-2016, 07:17 PM   #10
AG1LE
AG1LE's Avatar
Drives: '14 1LE
A good tune can help calm that down
AG1LE is offline   Reply With Quote
Old 01-16-2016, 09:59 PM   #11
jwcassidy1969
Drives: 2018 red hot 1le
Did you buy the car new or used ? I have a cam in my 1le and you will need more gas if cammed hell I can't even run under 1200rpm without bucking in all gears. If you start bucking with out a cam you are definetly not giving it enough gas and may need some more practice using a clutch.
jwcassidy1969 is offline   Reply With Quote
Old 01-16-2016, 10:20 PM   #12
AGM 1LE
AGM 1LE's Avatar
Drives: 14 SS/ 1LE
I hope one would be able to tell if a car is cammed lol. He said he got it used.
What OP is experiencing is normal. It can be worked around with practice. Just pop into 2nd and it will be much smoother
Old 03-22-2016, 04:50 PM   #13
ChristianLS3
Drives: 10' Camaro 2ss
Dude I thought I was the only one! Still haven't figured it out. I even told my tuner to hop in and do a street tune. Ofcourse, it didn't do it with him in the car. It does it all the time on regular driving. I get rid of it the same way as you do lol, either shifting to second or punching it.
ChristianLS3 is offline   Reply With Quote
