#15 |
![]() Drives: 2016 Camaro NFG 1SS A8 Join Date: Oct 2017
I tried this for the first time last night and................no...
![]() Had no problem getting it to do it but the launch was so fricking slow..........lol! For the first 10 feet it takes off just a little above idle........... ![]() Is that right or is there something wrong with it? |
#16 |
![]() Drives: 2016 Z06 coupe Join Date: Dec 2016
I also believe if you take the gas pedal off the floor even just a little it shuts down the mode.
#17 | |
![]() ![]() ![]() ![]() ![]() Drives: 18 Silverado 1500 Join Date: Dec 2015
#18 |
![]() Drives: 2017 1SS camaro ,2SS a 68 + 08 C6 Join Date: Dec 2017
If it is bogging down you are powering braking it with the gas and brake pedal mashed , it is NOT in Competitive mode. you must verify the dash says " competitive mode " then wait one second minimum before you release the brake maintaint wot on the accelerator pedal and yeeaaa hhaaawwwww !! 1.7 60 fts on stock tires are where its at , your dash data performance center should give you 0-60 MPH in the 3.9 - 4.2 in a prepped track and 4.0-4.5 range on a no prep/ public street ( obey speed limits of course , and drive safely of course )
#19 |
Rawr!
Drives: 2018 Garnet Red Camaro 2SS Auto Join Date: Sep 2013
I wasn't in competitive mode. Thank you.
Current: 2018 Garnet Red Camaro 2SS A8
2020 Lunar White Alfa Romeo Giulia 2.0 Ti (JB4 tune) Ordered: C8 Corvette Mist Red 2022 |
#20 |
#21 |
That wasn't so bad now was it?
Just got mine three days ago and I needed too know. |
#22 | |
![]() ![]() Drives: 2017 Camaro SS Fifty Join Date: Oct 2016
That is what mine is doing. No wheel spin to cause the slow takeoff. |
#23 | |
![]() Drives: 2020 Camaro 2SS A10 Join Date: Jun 2018
You can't feel that with LC and you put a lot of faith in electronics designed under a single condition and not various conditions/situations. My car is not a 1LE I can't put faith in LC to know what to do after I switched from 275 rears to 305 rears. All I know is my TC kicked in at 60mph shift points with 275 rear tires I knew I needed better and wider tires. And that was before my mods. I don't expect LC to be tuned for that change. |
Thread Tools | |
