02-05-2017, 09:01 AM | #1 |
Drives: 2010 camaro 2ss Join Date: Jun 2014
Can't remove rear axle from diff! HELP!
Got the passenger side out with a pry bar but the driver side won't come out! I've got a 2010 ss and I'm looking to put DSS axles in but this damn drivers side axle won't come out. Any tricks guys? Thanks!
02-05-2017, 11:05 AM | #2 |
You have to give it a really good tug. Make sure you are coming straight out. Yor should feel the cv joint kind of feel a little springy feeling, then it should get hard again and kind of clunk if I rember correctly.
02-05-2017, 11:25 AM | #3 |
I even tried using a slide hammer to get it off and its still stuck on
02-05-2017, 02:29 PM | #4 |
Drives: 2015 Summit White 2SS 1LE Join Date: Feb 2012
Yeah something is wrong if a prybar won't do it. Clip may be broke.
Retired wanna be cylinder head porter
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter Totalled: 2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X |
02-05-2017, 08:46 PM | #5 |
Bo might be wright about the clip??
09-19-2019, 02:49 PM | #6 |
Drives: 2010 Camaro 2SS/RS M6 Join Date: May 2009
Isn't it neat when the OP doesn't come back to explain how they solved the problem? I'm having the same issue.
GPI SS2; EE E2 catch can; SP 1 7/8" LT Headers w/ hfc; FM AT 3" cat-back; CAI Cold Air Intake; AEM Wideband
Tuned by GPI McCleod RXT; MGW flat stick; Ram Clutch slave cylinder & hydraulic adjuster BMR cradle & diff bushings, trailing arms, toe rods & upper control arm bushings Hotchkis sub-frame brace Stop Tech Z-23 brakes 4.10 gears, Eaton Truetrac, LPW diff cover Best 1/4 mile 12.073 @ 115.68 mph 3,300 ft DA |
09-20-2019, 02:10 AM | #7 |
Drives: 2015 SS/RS 1LE Join Date: Dec 2014
I had the same issue. The cheap ass pry par I was using would flex a little so I couldn't get a good pop on it. Once I switched to one that wouldn't flex it popped out. Not sure if that is your issue, just sharing my experience.
09-20-2019, 09:48 AM | #8 | |
I decided that maybe I can hit it from the other side, so I removed the PS axle. That one came out on my second attempt with the pry bar: I can see the other axle, and I tried to use a 12" long 3/8 extension to knock it out from the passenger side with no luck. This is getting old. I'm thinking I'll just pull the entire center section and deal with it on the bench.
09-20-2019, 02:30 PM | #9 |
Drives: Never just fly under the radar Join Date: Jul 2015
Just a thought and you probably tried it, perhaps try turning/spinning whats left of the shaft into other positions and prying/pushing it out. Maybe if you get it in just the right spot it will pop loose.
GL and please try to remember and post how it goes.
Old Skool |
09-20-2019, 03:00 PM | #10 |
Drives: 2014 Camaro 2SS Join Date: Feb 2015
There is a tool, which is a slide hammer with a CV shaft attachment that may be of help. Most people use a prybar, but taking a chance damaging a boot or the shaft itself. If you only have a prybar, you can pry outword and use a hammer to tap on the prybar as you push.
09-20-2019, 03:03 PM | #11 |
FYI, some of you may be tempted to remove the C-clip before reassembly. This clip is what prevent the shaft from popping out when turning and the suspension is loaded to one side or the other. This is especially true for front wheel drive cars where the steering angles change much more drastically when turning. The rear however, isnt as prone to this but it can still happen.
09-20-2019, 03:41 PM | #12 |
yeah, I've tried it in just about every position of the clock. I'm going to try to pound it out from the passenger side again tonight. I'll keep trying to rotate it, hoping I can find the magic spot. Maybe I can avoid removing the entire diff.
09-20-2019, 03:43 PM | #13 | |
09-20-2019, 04:52 PM | #14 |
I've seen broken shafts from people pounding and praying on them. But it's your car do what you want.
