Old 04-22-2019, 01:04 PM   #1
S.T.A.R.
Drives: 18'-1LE
Tire question...
A friend has a ZO6 with Cup 2's on it, they have approximately 1900 and six sessions on them from two days a Pocono.
He had it out yesterday and it was a hand full to say the least, just typical street driving. The tires were warmed up with 70 degrees air temps.
It never really got better...what's up with his tires?
S.T.A.R. is offline   Reply With Quote
Old 04-22-2019, 01:06 PM   #2
Lafourche1
Drives: 2019 CLA 450 Mercedes
Wore out would be my guess. The Cup 2s are very much a track tire and 2-3 track days and 2,000 miles could be the end of the tires.
2019 Lunar Blue Metallic Mercedes CLS 450
2021 C43 AMG Mercedes Coupe Metallic Cardinal Red
2014 Lincoln MKT EcoBoost (The Bus)
Lafourche1 is offline   Reply With Quote
Old 04-22-2019, 02:15 PM   #3
Aliveguy5
Drives: 2017 Red Hot ZL1
If they were truly warm, and it wasn't hooking they are probably heat cycled at this point. I had the same issue with my Toyo's at the end of the season last year and my times were a couple of seconds slower consistently per lap.
Aliveguy5 is offline   Reply With Quote
Old 04-22-2019, 04:34 PM   #4
Can'tHave2MuchHP
Can'tHave2MuchHP's Avatar
Drives: Fast
Fresh Cup 2's stick like a barnacle...Old and cold Cup 2's are slick as snot on a doorknob.
However, normal street driving at 70 degrees will not get the Cup 2 fully up to temp. As someone who drives on Cup 2's weekly in the summer, it takes hot pavement and some aggressive driving to get them on the warm side, and full on hard driving to get them hot.
Old 04-22-2019, 04:37 PM   #5
Squatch
Camaro pilot
Squatch's Avatar
Drives: 69 Camaro, 2014 ZL1
HAHHAAHAHAHAH
2014 ZL1 Camaro
1969 Camaro
Squatch is offline   Reply With Quote
Old 04-22-2019, 05:25 PM   #6
S.T.A.R.
Drives: 18'-1LE
Thank you.
Old 04-22-2019, 05:26 PM   #7
S.T.A.R.
Drives: 18'-1LE
Can'tHave2MuchHP;10498127]Fresh Cup 2's stick like a barnacle...Old and cold Cup 2's are slick as snot on a doorknob.
However, normal street driving at 70 degrees will not get the Cup 2 fully up to temp. As someone who drives on Cup 2's weekly in the summer, it takes hot pavement and some aggressive driving to get them on the warm side, and full on hard driving to get them hot.[/QUOTE]
Okay, I'll give it to him just like that!
Old 04-22-2019, 05:28 PM   #8
S.T.A.R.
Drives: 18'-1LE
I a suppose $1600 set is in his future.
Old 04-22-2019, 05:42 PM   #9
Artos
Artos's Avatar
Drives: A10 LT4
Sounds like the cup 2 is similar to the oem factory...
Artos is offline   Reply With Quote
