10-23-2023, 01:42 PM | #1 |
Drives: 2020 Camaro SS 1LE Join Date: Apr 2022
Clicking from rear right
Im getting a clicking sound when i initially apply power. Heres a vid of me turning the rotor to make the sound. I’ve never diagnosed an issue like this. Any suggestion on what I should look at first?
I’ll post a link to the youtube video in a minute. |
10-23-2023, 02:24 PM | #2 |
Nightmare
Drives: Your mom crazy in bed Join Date: Mar 2011
Without seeing the video, it's most likely the Thrust Washer issue.... was a common thing on the 5th gen, seen several 6th gens have it happen too...
Since you're getting it while the wheel is off, that would rule out a torque'd lugnut issue.
10-23-2023, 09:14 PM | #3 |
https://youtube.com/shorts/Ies_f9FIv...b3QlkHkiZhjBFD
Heres the clip of the sound. Thrust washer issue I’ll look that up. |
10-23-2023, 10:13 PM | #4 |
Nightmare
https://www.camaro5.com/forums/showthread.php?p=4991431
If that helps... I don't think that's the same noise however.... yours sounds much louder, almost like a bad shaft..
10-23-2023, 10:31 PM | #5 |
Drives: Camaro Join Date: Jun 2023
Mine just started doing something similar. I just recently got two new rear tires , however and that’s when it started. Figured my issue was lugnuts not torqued properly though as my fronts had similar issues. Will keep an eye on this thread in case the noise comes back.
10-24-2023, 05:57 AM | #6 | |
10-25-2023, 01:36 PM | #7 |
Drives: '23 1SS 1LE Join Date: Jul 2019
Following this thread. I have a 'click' almost 'knocking' sound coming from the rear right as well.
Only notice it in the first few minutes of a drive. The noise happens for about 1-3 seconds maybe 1 or 2 times. After that don't hear it for the rest of the drive. I don't think it's a torqued lug nut issue because I've made sure multiple times they're all at 140. |
10-25-2023, 02:35 PM | #8 | |
Drives: 2023 Chevrolet Camaro 2SS 1LE Join Date: Jan 2020
Current: 2023 2SS 1LE
Prior: 2016 Camaro 1SS 2007 Mustang GT 2008 Civic Si |
10-26-2023, 02:45 PM | #9 |
Drives: 2021 C8, 2022 Camaro 2SS Join Date: Jul 2015
You may want to check your axle nuts:
https://www.camaro6.com/forums/showthread.php?t=573305&highlight=axle+shaft+nut
Order 9/09/2021,2022 2SS, NPP, 56W whls, B04 stripe, AQJ seats, N26 strg. whl., SLN brace
3000 1/19/2022 3400 1/25/2022 TPW 1/31 3800 2/15/2022 4300 2/19/2022 4B00 3/04/2022 4000 3/8/2022 Delivered 3/9/2022 ____________________________________ Order 6/01/2016 2017 2SS, NPP, 56R whls 3000 6/08/2016 3000 6/15/2016 TPW 7/18/2016 3400 7/7/2016 4200 7/25/2016 Delivered 7/28/2016 Sold May 2020 |
10-27-2023, 12:44 PM | #10 |
Thanks Buck50, didn't know about this issue. Will definitely check this early next week when I'm with my car.
I'll update if this fixes anything. |
10-30-2023, 11:19 AM | #11 |
Update
So after torqueing both wheels down I’m still hearing the noise unfortunately. Couple things, one of the axle bolts did look like it may have loosened 1/4 turn, it still feels tight though. It’s also on the opposite side of where I hear the noise. I watched the thrust washer video and it does sound like it a bit…. More of a subtle click than a clank. Also, mine is m6. It’s possible mine has been doing this for a long time but wasn’t hearing it do to windows up and ac blasting. Lastly mine goes like this. On throttle - click Off throttle and coast in gear - click Repeat. |
10-30-2023, 12:09 PM | #12 | |
Nightmare
10-30-2023, 02:06 PM | #13 |
About that thrust washer video. Not sure if it’s auto or manual, but that car makes the noise when putting it in gear. My car only does it when engaging throttle, or letting off throttle.
