Old 10-22-2018, 10:20 AM   #1
Dubchitts
Dubchitts's Avatar
Drives: '17 Red hot 2ss, 16 Focus RS
2nd gear problems tr6060
Does anybody have the problem where shifting in higher rpms, you get "locked out" of 2nd? Namely above 6k? If I shift around there it's fine but if I actually go to 6700 it won't go. It just grinds. Obviously shifting at 6k kills my ETs. 2>3 and 3>4 work fine Everytime.
Anyone have any solutions? I remember reading a while back that the gt500 guys would pull the shifter towards them while going to 2nd. It worked for some and not for others.
It's done it since I bought the car. I have already flushed the fluid and have redline d4 right now, which has helped 100% with the 2nd gear notchiness during normal driving.
"Spitfire" 427ci
2017 Red Hot 2SS// 6 Piston Brembos//Adrenaline Red Interior, Knee Pads//M6//MRC
Afe Air Filter//BMR MM010 Motor Mounts, Safety Loop//Custom OTR Intake//Flex Fuel Kit//Gforce 3.5" Aluminum Driveshaft//GM 95mm TB//Katech Oil Pump, Piston Squirters//Kooks 1-7/8 LT//LT4 Fueling//Mighty Mouse Wild//Monster Clutch LT1-S Triple Disc//MSD 2-Step//Pray Performance Custom Spec Cam, Ported Holley Hi-Ram//Sikky 12" Shifter w OEM Knob Mod//Tick Level 1 Tr6060//Labor by Me//Tune By Pray Performance
Dubchitts is offline   Reply With Quote
Old 10-22-2018, 12:29 PM   #2
6spdhyperblue
Drives: 6th gen
How often do you flush your clutch/brake fluid?
‘16 1SS M6 LT2 intake + boltons on DR 11.0@126+ (Sold)
Old 10-22-2018, 01:16 PM   #3
Dubchitts
Dubchitts's Avatar
Just this winter. It's not dailyed. Weekends only with some occasional abuse at the track
"Spitfire" 427ci
Old 10-22-2018, 01:51 PM   #4
6spdhyperblue
Drives: 6th gen
Maybe the shift fork pad is fubar. But the rpm part of it leads me to the clutch disengagement
Old 10-22-2018, 08:46 PM   #5
torqueaddict
Drives: Tesla M3 LR-AWD [Former 1SS owner]
Haven't had that problem, but then, I hardly ever shift that high in 2nd. 6700 is approaching fuel cut-off on a stock SS from what I understand. In your case, it might be different.
torqueaddict is offline   Reply With Quote
Old 10-23-2018, 02:53 AM   #6
Dubchitts
Dubchitts's Avatar
Iirc an actual fix was to upgrade to the carbon blocker set for 2nd gear. Maybe I'll have that done this winter and do the bronze shift fork pads for all gears, and tailshaft bearing upgrade. While they're in there they can see if I need a new second gear and shift fork. As many times as it's happened now I can't imagine they aren't a little damaged.
Looking back at some logs I was doing 64-6500 (still low, but I think the previous year of it locking out had me too nervous to try any higher) successfully all year (with redline d4) up until the last time out.
Maybe it's a cold problem? It happened 3 times out of the blue that day, one on my best 60' to date, then it was good for the following pass, then 2 in a row it locked me out/grind. At that point I cut the track day short by about 2 hours.
"Spitfire" 427ci
Old 10-23-2018, 06:27 AM   #7
6spdhyperblue
Drives: 6th gen
I really thought these had the carbon blockers and triple cone synchros in the lower gears factory. That being said I did own a t56 that I mailed to a shop and it was a huge improvement. Not sure if u have anyone local but Someone like tick or Texas drivetrain perf would do an awesome job and u just mail it in a Tupperware. It was easy
Just make sure you install a slave remote bleeder once you’re in there
Old 10-23-2018, 06:29 AM   #8
Vtor_ZL1
Who Needs to KNOW?
Vtor_ZL1's Avatar
Drives: 18 ZLE
Tried no lift shift ?
ing for grip.
http://www.motorsportsne.com/
Old 10-23-2018, 06:57 AM   #9
Dubchitts
Dubchitts's Avatar
From one to two, no. The rest of them, yes. It's always made me nervous to try it with it not wanting to go while lifting.
"Spitfire" 427ci
