Old 04-06-2024, 07:58 PM   #1
GreyGhost702
Drives: 2019 Camaro 1SS1LE
Steering Wheel Reset Procedure?
So I am doing a LT header install and was pulling my wideband sensor through the firewall and braced myself using the steering wheel which turned. I didn’t think about it til I got out, and I don’t recall the position but the shaft is out of alignment for sure. Is the reset the same procedure as the Mustang? Turn the wheel all the way left til you hit the stop, turn right and count til it hits the next stop, and turn back half those turns and it’s set straight?
2019 1SS1LE M6 Shadow Grey Metallic
4/2/2024 "Under the Knife..." Build in progress
Previous Rides:
1996 Ford Thunderbird V8 - PI Swapped & Comp Cammed 310whp/330wtq (SOLD 2003)
1991 Ford Thunderbird SC - Ported & Tuned (CEF 2005, SOLD 2005)
2001 Mustang V6 (SOLD 2006)
2008 Mustang GT M5 - Procharger D1SC 440whp/480wtq @8psi (SOLD 2013)
2013 WRX M5 - Cobb Tuned (SOLD 2017)
2014 Focus ST - Cobb Tuned & Re-piped Hot Side (SOLD 2019)
GreyGhost702 is offline   Reply With Quote
Old 04-06-2024, 10:28 PM   #2
GreyGhost702
Is there a way to make the backup camera turn on without starting the car and putting it in reverse? I turned the car “on” by pressing and holding the start button without cranking, put it in R but nothing. Reverse lights won’t even come on. The shitty part about modern cars, too smart for their owners good. This would have been an easy fix for an older vehicle.
Previous Rides:
Old 04-07-2024, 04:04 PM   #3
GreyGhost702
For the record, if you ever end up in my situation, don’t panic. Once you put the car on the ground ready to run, you can fire it up and put the car in R and use the backup camera path lines to determine your steering angle. Turn the wheel accordingly, and bolt your steering shaft back up.
Previous Rides:
