05-26-2018, 07:18 AM | #15 |
Drives: 2018 Hyper Metallic Blue ZL-1 M6 Join Date: Aug 2017
No tune, as far as numbers go this is the base line reguardless of already having the TB installed. Let’s see where it ends up after completion.
2018 ZL-1 Hyper-blue, Heads, Cam, Exhaust, Pulley, CAI, ported TB. 720HP/715TQ.
05-26-2018, 01:24 PM | #16 |
08-15-2018, 12:15 PM | #17 |
Update: numbers on 93 pump gas ended up 720HP and 715TQ. These numbers and a M6 equate to no traction in the first 3 gears.
I need to kill some bottom end in the 2nd stage of this build and that’s what the larger blowers look to do. I did get a response back from Edelbrock and a part number for their LT4 TVS2650 p/n 155920 will be available in October. I’m leaning this way with the DSX low side and calling it done.
08-15-2018, 01:08 PM | #18 | |
Drives: 2023 Black ZL1 Auto Join Date: Oct 2009
08-23-2018, 09:49 PM | #19 |
08-24-2018, 11:19 AM | #20 | |
Dyno Show Queen LOL
I have been pricing the exact same parts except a smooth idle cam... I came to conclusion it will be cheaper just to buy a LT5 motor then sale my LT4 motor.. the benefits will be port injection and lower IATs with similar flow from the blower.. WITH the ability to make power more economically.. Great build though.. The cost of this DI crap is for the birds!
08-25-2018, 01:11 AM | #21 | |
Drives: 2017 ZL1 Join Date: Jan 2018
08-25-2018, 08:19 PM | #22 |
Just because I can.
08-25-2018, 09:05 PM | #23 |
08-25-2018, 09:33 PM | #24 |
I have a couple opinions, it really depends on your end goal and then not changing your mind mid stream.
For the money here’s the ticket to good HP. TM TB and ROTO-FAB CAI. On my M6 nearly 600rwhp. Add the DSX low side with flex fuel sensor along with tune and your sitting on the 650-660 mark. Turn up the boost with either an upper or lower pulley and your looking at 20hp per pound on the first 2psi. Let’s just say 690 and your out 3.5k and pretty much maxed out on the low side. My build was totally planned around 93 pump fuel and I had to pay a premium on the front end of the build to have what I do but the advantages won’t be seen until I add the low side and bigger blower. Goal is 850 on gas alone.
08-25-2018, 09:41 PM | #25 | |
08-25-2018, 10:05 PM | #26 |
I did an 18% over drive and it’s working well, would do better on the e85 set up due to the cooling ability of the fuel. This little 1.7 blower makes a ton of low end TQ. On E85 it has to be a beast.
Unless you’re going to go bigger then what I outlined, I wouldn’t do the headders. You could do a cat delete and save some money. The factory “headders” flow pretty well. Not much power to be had for the money. Same holds true on the CNC ported heads, 3.5k plus labor for 35-40hp
08-26-2018, 12:25 AM | #27 | |
My main concern is being able to put any power to the ground. I suppose a R888r or a 17” Mickey (unstable) are basically mandatory even on a bolt on car. Last edited by Chris Edwards; 08-26-2018 at 01:09 AM. |
08-26-2018, 07:25 AM | #28 |
Putting power to the ground is all perspective, it’s not a dedicated drag car and you’ll not do it with low profile radials. 7-8 hundred ft pounds of TQ. Is going to blow away anything when your doing it pretty much off idle. To many people these days didn’t grow up behind a four speed, junk tires and old school big block HP with slapper bars and 6 cylinder springs in the front of say a 70 nova. 10.30’s in the 70’s was top of the class in D gas and pro stocks below us were in the high 9’s.
Everything is automated these days and drivers are just along for the ride anymore. That’s the expectation and anything other is unacceptable. I Love my car and set up, I know how to use my two feet and hands. I can still get it done old school. We have a four link rear and 2 speed power glide in our dedicated 2012 ZL1. Yea it’s a 4130 tube chassis, fiberglass body car. Two different Camaro’s build for two different reasons.
