Roto-Fab
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics
Old 05-22-2018, 10:05 AM   #15
JANNETTYRACING
JANNETTYRACING's Avatar
Originally Posted by PolarBearSS16 View Post
Appreciate it, Ted.
2.4" Upper Pulley
Rotofab Oil Intake
BTR Stage 3 PDS Cam (with springs and pushrods)
Muffler Delete Exhaust (still has original cats)
LS3 Throttle body
TR7IX Plugs
1050x Injectors
You absolutely need;
Long tube headers
JMS fuel pump voltage booster
Crank case breather
Catch can.
Likely a good custom tune.
You must make sure your intercooler is working and not full of air.
www.jannettyracing.com
Celebrating 37 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705
email tedj@jannettyracing.com
Old 05-22-2018, 10:20 AM   #16
WYKDZL1
Drives: Ashen gray zl1camaro
I had my car at 593rwhp on a VERY STINGY dyno with similar mods on a 18% lower pulley only difference was I was running a large heat exchanger catless mid pipes to factory exhaust and a tune from a very reputable tuner. My car beat allot of bigger power cars at this level, many 700+ cars. I still have my catles midpipes dm if interested I'll let them go for a good deal. Pushing as much boost as you are your going to melt your cats. And like Ted said you need a boost pump or a fuel system or you could blow your motor. Crank case breather highly recommended I'd also think about a different tuner that's one of the ugliest dyno charts I've ever seen.
WYKDZL1 is offline   Reply With Quote
Old 05-22-2018, 10:29 AM   #17
JB'sZL1
Drives: 2013 ZL1 and 2019 Ram Laramie
Yeah, that tuner should have never let it out of the shop with a tune like that. But in fairness, I never heard of doing a stage 3 cam w/ 1050's but no extra fuel supply and no headers.
JB'sZL1 is offline   Reply With Quote
Old 05-22-2018, 10:52 AM   #18
PolarBearSS16
Agent Orange
Drives: 2022 ZL1
In all fairness I was told id be fine the way I went so I guess that's on me for not doing better research. I'll get on with ordering the rest of the parts and turning my frown upside down.
PolarBearSS16 is offline   Reply With Quote
Old 05-22-2018, 10:58 AM   #19
RobZL1
fo'shizZL1
RobZL1's Avatar
Drives: 2017 ZL1
Any idea what the air temp was in the shop during the dyno pulls? Mine put down 629 in November with 60deg iat1's, but only 576 with iat1's at 113 at the beginning of each pull. You could have been pulling 4+ degrees of timing depending on the temp and if your tuner messed with the iat spark tables.
2017 ZL1 M6 Black | Maggie 2650 // 103TB // Big Gulp
Past Rides-
2014 ZL1 M6 Red Hot | Tons of mods
2004 CTS-V M6 Silver | Many mods
1995 Corvette M6 Torch Red | A few more mods
1992 Camaro M5 White | A few mods
Old 05-22-2018, 11:08 AM   #20
PolarBearSS16
Agent Orange
Drives: 2022 ZL1
It was 81.29 degrees... he did mention iats were up at 180 something
Old 05-22-2018, 11:08 AM   #21
silversleeper
Big Crow
silversleeper's Avatar
Drives: '13 ZL1
I'm with the consensus. I believe you should look at your fuel pressure under boost. It's likely dropping way too low. Remember you have to push fuel against the boost too so e.g. 45psi against 15 psi is like only 30psi of pressure effectively to squirt out the gas.
Also need race gas or e85 blend. And I think melted cats. That's assuming your tune is ok and cam installation was done properly. I don't know if you got bad advice or didn't listen but whoever said running more than 5% or 10% max pulley without racegas or e85 doesn't know boosted engines, maybe that's why you got melted cats now....
Edit: You posted while I was typing, so it was bad advice, ok got it. You NEED to check for melted cats or better yet go catless, and fuel pressure or your engine might not last.
silversleeper is offline   Reply With Quote
Old 05-22-2018, 11:25 AM   #22
RobZL1
fo'shizZL1
RobZL1's Avatar
Drives: 2017 ZL1
Here's my opinion:
That's a big part of it. At 180 iat2's, you were pulling 10 degrees of timing if the tuner kept the stock iat/airmass/advance table.
That said, if shop air was 81 degrees, IAT2's should have only been maybe 140 maximum (assuming you had decent air flow in front of the car).
Perhaps your intercooler/HEX loop has some air in it?
Past Rides-
6 speed, dyno, guess, zl1
