04-07-2017, 11:43 PM | #1 |
Humble
Tsp 231/246 cam Installed untuned
View it here https://youtu.be/TqJvStoDkIY
04-08-2017, 04:05 AM | #2 |
Drives: Savitar; The 500rwhp N/A Monster! Join Date: Aug 2016
Sounds good man. Get that tune asap so you can maximize those gains
*SOLD*504HP/433TQ | Night Fury cammed Cold Air Inductions intake Bo White ported TB Speed Engineering 1 7/8 longtubes NPP catback QTP low profile cutouts Powerbond 25% UDP 3.73 gears JRE scoop ZL1 grille R1 Concepts drilled/slotted rotors built/tuned by Weapon X Motorsports
04-08-2017, 04:24 AM | #3 |
Drives: 2015 Summit White 2SS 1LE Join Date: Feb 2012
231/246?
04-08-2017, 04:29 AM | #4 |
New cams from TSP. Cool!
http://www.texas-speed.com/p-5762-ne...-camshaft.aspx |
04-08-2017, 08:54 PM | #5 |
Did you put new springs and push rods or just cam?
04-09-2017, 12:24 AM | #6 |
Humble
I did everything, new springs , rockers, pushrods, lifters, oil pump , hot tanked heads, resurfaces pretty much the sole 9 beside port polish and mill
04-09-2017, 12:25 AM | #7 |
Humble
04-09-2017, 12:26 AM | #8 |
Humble
04-09-2017, 01:53 AM | #9 |
Drives: 13' 1LE Join Date: Apr 2012
Sounds crazy!!! Get the tune ASAP and report!
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me. |
04-14-2017, 08:51 AM | #10 |
Humble
I'm getting tuned Monday and I will let you guys know the results, I have heard that my tuners dyno reads 20hp lower than what the car actually is so I will update soon
04-14-2017, 11:26 AM | #11 |
Doesnt matter on the dyno as long as you always use the same dyno. You know what youve gained based on baselines.
04-15-2017, 08:38 AM | #12 |
Humble
04-15-2017, 05:10 PM | #13 |
Drives: 2017 Camaro ZL1 A10 Join Date: May 2012
04-16-2017, 09:53 AM | #14 |
That video was to short you big teaser! Lol.
Car mods: never enough!
Tags |
cam |
