Roto-Fab
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics
Old 05-20-2018, 10:29 PM   #183
Zl1dad
Drives: 2013 zl1
Originally Posted by silversleeper View Post
I would, but whenever I try to support my local dealer buying parts, they really stick it to me with full MSRP.
Here is an example of an alternator
https://www.gmpartsdirect.com/oem-pa...aGV2cm9sZXQ%3D
$182 vs $338 msrp.
If it were even halfway in between, but almost double? I tend to order online; oh and the counter guy is very rude when you hesitate or ask about their full msrp's.
Have you looked at the shipping prices. Makes up for the discount.
Sent from my HTC 10 using Tapatalk
Zl1dad is offline   Reply With Quote
Old 05-21-2018, 09:14 AM   #184
silversleeper
Big Crow
silversleeper's Avatar
Drives: '13 ZL1
$27 shipping to me on that part. It is a consideration and I prefer to support local business when I can but I won't be bent over any longer by them.
For example I just ordered a pair of front wheel bearings from Rock Auto. Able to choose good quality Timken bearings at a low price.
silversleeper is offline   Reply With Quote
Old 06-02-2018, 09:48 AM   #185
ZMEnow
Drives: ZL1, 2013, tri-coat-red, manual
Originally Posted by incon3037r View Post
I wish I had a photo, but from my observation the outer part of the strut was covered in a thick layer of black oily dust. It wasn't a constant drip, but it was enough to make for a bouncy ride. It has also began to make a clunking noise over dips in the road.
Notice bouncy back when starting this season a month ago, put on the lift and both had a dusty slightly moist film on the lower strut, but no leaking like I have seen on fronts. At a Cars an coffee event this morning I had a chance to ask a few friends to let me bounce the rears with the truck open, and that confirmed they are definitely gone. 16780 miles..
ZMEnow is offline   Reply With Quote
Old 06-13-2018, 10:02 AM   #186
TTTAPOUT
Drives: 2013 ZL1
Mine look done at 42k miles. Gonna look into replacements
TTTAPOUT is offline   Reply With Quote
Old 06-14-2018, 01:41 PM   #187
ZMEnow
The interesting fact is GM/AC Delco just moved to a Unlimited Life time Warranty on these struts purchased after 4-1-2018.. They clearly noted only 12 months on any purchase before 4-1-2018.
I smell an improved strut..
Old 06-17-2018, 12:06 PM   #188
hntrgthrs
hntrgthrs's Avatar
Drives: 2015 ZL1
That’s really interesting and very good news. Have a link for that??
2015 ZL1 Coupe - Summit White | Stock (for now)
hntrgthrs is offline   Reply With Quote
Old 06-17-2018, 09:00 PM   #189
ZMEnow
The last link has the details page 17 and 18.
http://www.genuinegmparts.com/pdf/wa...nformation.pdf
http://www.genuinegmparts.com/resources/warranty-info
https://www.acdelco.com/auto-parts/s...oe-struts.html
https://www.acdelco.com/auto-parts/warranty.html
https://www.acdelco.com/content/dam/...Warranties.pdf
Old 07-27-2018, 06:16 PM   #190
evonschu
evonschu's Avatar
Drives: Camaro ZL1
My rear ones were blown at about 50k. I got them replaced at a shop I'm friends with the owner at in town. Do the fronts also typically wear out that quick? Debating whether I should have them do the fronts at some point in the near future as I won't have the same hookup in a few months and don't want to pay the dam dealer to do it. They seem fine now, but I know as soon as my hookup is gone they'll blow out cuz thats my luck. What have you all typically got out of the fronts? I have 53k miles currently.
2013 Camaro ZL1 M6: Rotofab CAI, JDP ZL-R Rough Idle Cam, Upgraded Valve Springs and Pushrods, Ron Davis Heat Exchanger, Alky Methanol Injection, Rx Catch Can, 87mm VMAX Ported TB, Summit Performance Spark Plug Wires, 10" Lower Pulley, Kooks 1 7/8" Headers with Magnaflow Cats, ID850 Injectors, Johnson 2110R lifters, EBC Slotted Rotors+Hawk Pads, Rotofab SC Coolant Reservoir, 160* Thermostat, Custom Mild to Wild switch, Tune, 1st to 4th bypass. 685 RWHP / 640 RWTQ.
evonschu is offline   Reply With Quote
Old 07-27-2018, 06:31 PM   #191
Hellfighter
Hellfighter's Avatar
Drives: 2013 Black ZL1
another reason for coilover kit
Hellfighter is offline   Reply With Quote
Old 06-26-2020, 07:01 AM   #192
Happy_Dan
Happy_Dan
Happy_Dan's Avatar
Drives: 2012 IOM Camaro ZL1 #569
Send a message via AIM to Happy_Dan Send a message via Yahoo to Happy_Dan Send a message via Skype™ to Happy_Dan
Joining the club. Font left leaking now. Time to consider coilovers.
Happy_Dan is offline   Reply With Quote
Old 07-02-2020, 12:56 AM   #193
CJ27
Drives: Chevrolet camaro zl1
Did they at least make these where you can replace them without needing an alignment afterwards?
2014 Sliver ZL1. Built engine, Stage 1 Frankenstein heads, Magnuson, SW long tubes, AFCO H/E, She Gone cam, flex fuel sensor, meth injection. 820rwhp e85.
CJ27 is offline   Reply With Quote
Old 07-02-2020, 09:12 AM   #194
Full_Spectrum
Drives: 2013 ZL1
That isnt a thing.
If you replace a strut, you really should put it on the rack to verify the alignment.
Full_Spectrum is offline   Reply With Quote
Old 07-02-2020, 11:20 AM   #195
ZMEnow
Yes, the GM procedure for the fronts has an indicated ares to highlight or scribe with a marker on the ARM so you may put it back in the exact position. It has worked perfectly for me. The rears you don't touch any of the concentrics so you are good.
Old 07-02-2020, 07:16 PM   #196
CJ27
I do the same when changing them. Just hoping maybe this design was different...
blown, struts, zl1
