Old 09-21-2020, 05:17 PM   #1
V1LE SS
V1LE SS's Avatar
Drives: 2018 1LE SS
KR and Misfire count
Quick question, car is intake E headers and IM. Recently started detecting KR and a misfire count consistently showing anywhere from 2-10. No kr under wot, but shows a range of .5-6.7 sporadically for under part throttle (for example passing a car on the highway, getting up to speeds). Timing where it’s happening has been reduced, ran through two tanks of E from two different gas stations to rule out bad gas, and plugs look good. Does anyone have any ideas?
18' MBM 1SS 1LE, PDR
2" Speed Engineering headers
Lethalgarage flex fuel sensor
LT2 non ported Intake manifold
Rotofab-CAI
mishimoto catchcan
V1LE SS is offline   Reply With Quote
Old 09-21-2020, 05:54 PM   #2
LiqTenExp
LiqTenExp's Avatar
Drives: 2017 ZL1
What are those mods? Intake, headers, intake manifold I think? What level of tuning was performed? What kind of instrumentation/gauges do you have?
Check spark plug wires to coils and plugs (should hear/feel one/two clicks on coil and one on spark plug). Check coil pack wiring, make sure that when you pull off each that there are no contacts recessed due to broken connector contact locks.
Old 09-21-2020, 05:54 PM   #3
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Knock Sensor sensitivity needs adjusted in the tune.
2016 NFG 1SS A8
Options-2SS Leather/NPP
Old 09-21-2020, 06:37 PM   #4
V1LE SS
V1LE SS's Avatar
Drives: 2018 1LE SS
Lt2 intake mani, 2” headers. Rotofab and E. Watching via scangauge.
Rotofab-CAI
mishimoto catchcan
Old 11-02-2020, 07:27 AM   #5
Kilo_SME
Drives: 2016 Camaro 2ss
Did you figure out your issue? I have almost the same mods and mine does the same thing.
Kilo_SME is offline   Reply With Quote
Old 11-02-2020, 07:28 AM   #6
Kilo_SME
Is this commonly done with these cars? I don't want to blow some shit up lol
Old 11-02-2020, 11:45 AM   #7
KingLT1
KingLT1's Avatar
Yes it's commonly done...these engines show false KR stock. They command 24 degrees and often your lucky to see more then 22 consistently.
2016 NFG 1SS A8
